Bushings? We don't need 'um, ...ummmm, yes we do! |
Black22 |
Apr 7 2014, 11:00 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
So I took the car out on our 1st 75F day here, just to stretch her legs. I seem to get some pinging at the high end on the RPM range. Changed timing multiple times. Can't quite get it yet.
So as I walk toward the teener from the rear, it looks like the passenger wheel is leaning inwards at the top. I compare it to the drivers side. BIG difference!!! My first thought. Cracked console ear! NOOOOOOOO! I jack up the car, grab the wheel and I can move it an inch up and down!!! (IMG:style_emoticons/default/WTF.gif) So I pull her back in the garage and (luckily) in about 30 minutes I have the trailing arm off the car and I find this... There is supposed to be a bushing there, No? (IMG:style_emoticons/default/lol-2.gif) Just placed my order to Eric at PMB. (IMG:style_emoticons/default/smash.gif) These are literally the only things I have never replaced on this car! Ear is fine, no ovaling or cracks. (IMG:style_emoticons/default/pray.gif) Trailing arm came off nicely. Car still had the caps on the three outside console bolts! Eugene, Oregon alignment shop recommendations anyone? |
ConeDodger |
Apr 7 2014, 11:32 PM
Apex killer! Group: Members Posts: 23,758 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Roads are so good in Oregon you don't really need bushings, right?? (IMG:style_emoticons/default/biggrin.gif)
Black22 |
Apr 8 2014, 12:12 AM
Roads are so good in Oregon you don't really need bushings, right?? (IMG:style_emoticons/default/biggrin.gif) Ummm...no. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/av-943.gif) |
bdstone914 |
Apr 8 2014, 07:40 AM
bdstone914 Group: Members Posts: 4,673 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Are you replacing both sides? The other arm may be ready to go out too.
Matt Romanowski |
Apr 8 2014, 07:56 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
You didn't notice that driving? It must have been going bad for a while.
914_teener |
Apr 8 2014, 07:18 PM
914 Guru Group: Members Posts: 5,245 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I'd do both sides like Bruce suggests.
Are you sure the pinging isn't from bad fuel? I'd add some fuel treatment first...... |
Black22 |
Apr 8 2014, 09:20 PM
Yeah, I'm going to do both sides. The only indication was the leaning tire! It creaked and groaned on that side like most teeners with poly bushings do when pushed down on that side.
Drove fine.......or did it? It may feel like a Caddilac when I'm done. (IMG:style_emoticons/default/lol-2.gif) I suspect bad gas too, but I just added octane booster to the tank and only drove 1 mile before I tore into the trailing arm. (IMG:style_emoticons/default/dry.gif) |
914_teener |
Apr 8 2014, 09:59 PM
I am thinking you,ve maybe got water separation in the fuel...and hence the pinging.
Since you don't live in Sunny So. Cal anymore.....and the car has been sitting...maybe that was what it was. Anyway.....put zerk's in the new bushings when you get everything together....one per bushing. It shouldn't be squeaking when you are done. Hope everyone is fine up there. |
timothy_nd28 |
Apr 8 2014, 10:22 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Bushings look fine. Fill in the cavity with some great foam. (IMG:style_emoticons/default/bye1.gif)
ThePaintedMan |
Apr 8 2014, 10:37 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
(IMG:style_emoticons/default/av-943.gif) I like it. How about just welding the trailing arms to the ears? You know, for that classic "Hard Tail" ride. |
Black22 |
Apr 9 2014, 12:00 AM
How about just welding the trailing arms to the ears? You know, for that classic "Hard Tail" ride. Might have to! (IMG:style_emoticons/default/blink.gif) Got the old bushings out! 914 part # on them?!? Would these be original? Pulled the first shaft out and this is what I found! MAJOR rust deterioration! (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/ar15.gif) |
brant |
Apr 9 2014, 06:54 AM
914 Wizard Group: Members Posts: 11,739 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Shafts are around and might be worth it
r_towle |
Apr 9 2014, 06:59 AM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Chris foley sells a new setup with shafts.
Www.tangerineracing.com |
brant |
Apr 9 2014, 09:32 PM
I think I may have a pair of excellent stock also
DRPHIL914 |
Apr 10 2014, 07:06 AM
Dr. Phil Group: Members Posts: 5,808 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
mine were all original and upon removal were pretty rusted, sagging on the right after having put the new shocks and springs on - i got newly repowdercoated ones from Bruce stone, new pivot shafts and bushings from Eric Shea - he also put in the zerks for me!, but also check with Chris Foley, he does these as well and you can get them either black or orange- I got my C.V.'s from Chris . you might as well do it right and do both sides at the same time.
Lo-Fi Version | Time is now: 27th September 2024 - 12:56 PM |
