A-arm u-tab dimension? |
RustyWa |
Jan 14 2005, 05:32 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
So what is the dimension for locating the u-tabs on the a-arms? I've seen it different ways. The Pelican article gives one dimension but they don't say from where to where....
I'm going to try and weld these on this weekend. At least the welds will be horizontal flat, so it should be fun.... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Thanks. |
SirAndy |
Jan 14 2005, 05:47 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i did a "custom" location/rotation because of the droplinks. they would bind on the u-tab if the bar is set on full soft or hard. i turned them 90 deg. and now it's just fine. in this configuration, they will bind if the suspension is fully unloaded (like when the car is on the lift) but otherwise clear. the best location for you depends on your sway-bar. you want the droplink to go down in a straight line when the car is loaded (on the ground). (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy Attached image(s) |
Jeroen |
Jan 14 2005, 07:54 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
here's were I put mine (same location as stock u-tabs)
Attached image(s) |
RustyWa |
Jan 15 2005, 01:26 PM
Thanks guys. I'll try to get them on this afternoon.
RustyWa |
Jan 15 2005, 07:41 PM
Ok got the u-tabs welded in...and my welding skills still suck.
Lo-Fi Version | Time is now: 27th September 2024 - 07:57 AM |
