914 Rubber Help ! Plastic parts needed ! Who else needs these? |
pete000 |
May 19 2014, 12:10 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I am not able to located a couple plastic bits for my projects.
First does any one know if these parts are still available? Second, If NLA can 914 Rubber step in and make them... (IMG:style_emoticons/default/chowtime.gif) First up is the rubber deck hinge stoppers for the engine cover. Mine and all that I have found are cracked and all busted up. (see photos) (IMG:style_emoticons/default/hissyfit.gif) With out them the lid hits the targa bar at fully open. (IMG:style_emoticons/default/hissyfit.gif) Next up is these little caps found on the interior and under the rear targa bar. I have found a few different styles of basically the same cap. Some have no grain, and there seems to be two different sizes. The one for under the targa bar need to be the smaller size. (See photos) Both my projects have these caps missing. (IMG:style_emoticons/default/hissyfit.gif) Seems these pesky caps seem to fall off the interior easily and it would be nice to have a bunch of spares ! (IMG:style_emoticons/default/chowtime.gif) Thanks ! Attached image(s) |
JeffBowlsby |
May 19 2014, 12:12 PM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
my goof...
pete000 |
May 19 2014, 12:15 PM
Part 13 does not look like your photo...that part should be readily available even new. The part in your photo may be for the front trunk bottom front holes It is the part, I have four engine covers and it is the same part on all four. Its a rubber stopper. Take a look in your engine compartment and you will see it. I tried one dealer, but they are not the best around. |
Krieger |
May 19 2014, 12:59 PM
Advanced Member Group: Members Posts: 4,754 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I have always found nice ones on the outside of the car under the spare tire/front trunk. They are the same and if your lucky there are two.
saigon71 |
May 19 2014, 01:05 PM
Advanced Member Group: Members Posts: 2,006 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
No help on the rubber stoppers.
For the plastic caps - take a trip to Lowes. I found some there that fit the openings in the targa pad perfectly and look great too! |
bulitt |
May 19 2014, 02:12 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
dlkawashima |
May 19 2014, 03:49 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
Next up is these little caps found on the interior and under the rear targa bar. I have found a few different styles of basically the same cap. Some have no grain, and there seems to be two different sizes. The one for under the targa bar need to be the smaller size. (See photos) Both my projects have these caps missing. (IMG:style_emoticons/default/hissyfit.gif) Seems these pesky caps seem to fall off the interior easily and it would be nice to have a bunch of spares ! (IMG:style_emoticons/default/chowtime.gif) Thanks ! If you google 7/16" Diameter Head, 7/25" Diameter Hole you should see a link for Amazon and a couple of other places that sell a plug that closely matches the original's head shape (which is the thing that really matters). Only problem is they sell them in packages of 100. |
pete000 |
May 19 2014, 04:22 PM
Thanks for all the leads !!
pete000 |
May 19 2014, 04:25 PM
This is the superseded part, not the same, but with a sharp knife it might be able to be whillteld down to work. I have a bunch of these later style. Was hoping for something closer to the OEM 914 part which seems to be NLA. |
Cap'n Krusty |
May 19 2014, 05:25 PM
I have a pair of those in hand, and they don't even remotely resemble what you want. They actually screw in for height adjustment, and are used on the front and rear hoods of 911s. Note the helical groove.
The Cap'n |
914Sixer |
May 19 2014, 05:53 PM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Most on line VW parts places have the rubber adjust stops for under $2 new.
Steve |
May 19 2014, 07:53 PM
914 Guru Group: Members Posts: 5,686 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
At the last car show / swap meet Sierra Madre was giving away those stops for free. I think I grabbed two. They advertise on this board.
Lo-Fi Version | Time is now: 27th September 2024 - 08:54 AM |
