Engine knock after rebuild.....need advice |
LCOX |
May 26 2014, 01:07 PM
Member Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None |
This on going problem started after I rebuilt my 1.8 engine last year. Since then I haven't driven the car and I've put it on the back burner and finally ready to face it again.
Rebuilt the 1.8 with all new bearings and new rings. There is a definite engine knock at idle and throughout the rpm range. This is not a ticking noise like a valve out of adjustment but a bottom end knock. I did check valve adjustment and everything I could think of. When I pull the #3 spark plug wire the knock almost completely goes away but not completely but definetly better A couple members said it was probably a rod knock so with the engine in the car I pulled the head and #3 piston and cylinder and tried another rod but the knock is still there. So I guess take the engine apart and look for a mistake I made on the bottom end rebuild right? Anything else I can try? Thanks in advance. L |
ConeDodger |
May 26 2014, 03:36 PM
Apex killer! Group: Members Posts: 23,758 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Take it apart and mic the crank...
There is no way to fix a bottom end knock without pulling it apart. This is part of the responsibility of doing it yourself. That thing should have been out and apart right away. Staring at it will not fix it. You're the builder. Quit wishing and take it out. I know the paralysis you are feeling. It will not fix itself and asking a question here will not help. There is either something wrong with the rod bearing or the crank. Go find out... (IMG:style_emoticons/default/sad.gif) Good luck... |
earossi |
May 26 2014, 08:16 PM
Member Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest |
Cone Dodger did not mince words with you. Unfortunately, I believe that he is right on. Unfortunately, rebuilding one of these motors is not merely taking it a part and replacing parts with new parts.
You did not mention what dimensional checks were done on the motor, and what machining was required before reassembly. A rod knock is distinctive and destructive. Hopefully, you have not run the motor long enough to have damaged the crank. |
reharvey |
May 26 2014, 08:44 PM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
Cone Dodger did not mince words with you. Unfortunately, I believe that he is right on. Unfortunately, rebuilding one of these motors is not merely taking it a part and replacing parts with new parts. You did not mention what dimensional checks were done on the motor, and what machining was required before reassembly. A rod knock is distinctive and destructive. Hopefully, you have not run the motor long enough to have damaged the crank. (IMG:style_emoticons/default/agree.gif) It's a tuff thing to face but needs to be taken apart. I feel your pain because it has happened to me. |
ConeDodger |
May 27 2014, 12:11 AM
Self loathing I guess...
What we see sometimes is a reflection. I have done this myself, it didn't work out, you are putting off the inevitable because you 'wish' it would magically work out. My apologies for the harshness you might perceive. It was meant for me. You/I have wasted a year. Taking it out and apart will only take a weekend. |
Bartlett 914 |
May 27 2014, 06:17 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
My Son and I recently did a Nissan 240 motor. We failed to get oil pressure up in time. We had some difficulty with fuel and a timing issue. Result was a damaged rod bearing. My Son then went out to show is friends is new car. 50 miles later a total melt down. Metal in the oil ruined pistons and damaged calve train. Di is young and didn't stop soon enough to save the motor.
Tear it down. It will not get better |
saigon71 |
May 27 2014, 06:40 AM
Advanced Member Group: Members Posts: 2,006 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Did you have the case line-bored during the rebuild?
Years ago a buddy built a 1776CC type 1 engine. The case had to be line bored to true it up. When he fired it up, there was a horrific knocking sound. Upon investigation, he used standard bearings instead of the oversized ones required with a line bore. (IMG:style_emoticons/default/sad.gif) Good luck with the project and keep us posted as to what you find. |
r_towle |
May 27 2014, 11:05 AM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
you can pull and strip a motor in one day.
Then take the crank, rods and case to a machine shop for inspection. You will need to order a new gasket kit... you will need to order new rod and main bearings. I would hold off on any bearing order until you hear back from the machine shop. Could be two long weekends, fixed. Might be a few weeks in between for machine work to be completed... Don't avoid it, just get it done and you will be happier in the long run. It will also be alot cheaper to do it while you have not wrecked anything. |
76-914 |
May 27 2014, 11:59 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Did your valve train geometry change (higher lift cam)? If so check your valve covers for dents.
worn |
May 27 2014, 12:52 PM
can't remember Group: Members Posts: 3,290 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
This on going problem started after I rebuilt my 1.8 engine last year. Since then I haven't driven the car and I've put it on the back burner and finally ready to face it again. Rebuilt the 1.8 with all new bearings and new rings. There is a definite engine knock at idle and throughout the rpm range. This is not a ticking noise like a valve out of adjustment but a bottom end knock. I did check valve adjustment and everything I could think of. When I pull the #3 spark plug wire the knock almost completely goes away but not completely but definetly better A couple members said it was probably a rod knock so with the engine in the car I pulled the head and #3 piston and cylinder and tried another rod but the knock is still there. So I guess take the engine apart and look for a mistake I made on the bottom end rebuild right? Anything else I can try? Thanks in advance. L I think it is interesting that the thing changes when you pull the #3 plug. That means I assume that the others do not affect the knock? That tells you that the compression gasses in #3 deform something that goes clunk in the day. The most obvious is #3 rod at the crank. Replacing the rod was heroic, but if you were not able to mic the crank at the time I think inconclusive since if it was undersized at the journal it would still be with a new rod. Were you able to see anything of interest after you got the piston out? I can't see how not dropping the engine is going to get you anywhere. Seems like having the case on a stand is going to be easier than crawling over and under. Two winters ago I did sort of the same thing. I did all my own measuring and even decked the heads myself. It was gamble all the way, doing the math and compression ratios with home-made jigs. No line boring because I couldn't detect a need with feeler gauges and a straight edge. All along I knew it might have to come back out. I hope it is in 50-100k miles though. As one poster pointed out though it could be a lot less. Best of luck. One think you might use is one of those cheap stethoscopes. I was amazed using it when we lit the engine off - you can hear all the different parts doing their jobs and you can separate them out depending on where you touch the rod to. For anyone who hasn't tried it it, it is pretty wild. Have a go at it and see what you hear - at idle; for a short time. |
veekry9 |
May 27 2014, 06:27 PM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
"One think you might use is one of those cheap stethoscopes. I was amazed using it when we lit the engine off "
Yup,it works,as shown in the movie Das Boot. sorta like this.. And for some great reception.. Knock Knock.. Its a drag,but you gotta do it. Get yer wrenches out and dig in. (IMG:style_emoticons/default/chowtime.gif) |
larss |
May 28 2014, 02:32 AM
Member Group: Members Posts: 429 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
Dave_Darling |
May 28 2014, 04:02 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Removing at least the two front (or two rear) cylinders and pistons. Then you can work around the rod in the opposite half of the case.
A serious pain in the butt, if you ask me. --DD |
larss |
May 28 2014, 11:46 PM
Removing at least the two front (or two rear) cylinders and pistons. Then you can work around the rod in the opposite half of the case. A serious pain in the butt, if you ask me. --DD Thanks but I dont see how one can get the heads off, the valve covers in my 914 are WERY close to the surrounding bodyparts...I have problems in adjusting the valves and can not dream of lifting the heads over the head bolts...but if someone has done it it must be possible... /Lars S |
Dave_Darling |
May 29 2014, 12:30 PM
Oops, brain fart. For some reason, I thought you were asking about doing it without splitting the case....
Yeah, the motor comes out--no way around that. Not unless you want to sawzall the body up and then weld it all back together again after. (IMG:style_emoticons/default/wink.gif) --DD |
stugray |
May 29 2014, 12:53 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
It's a little easier for me because of carbs instead of FI, but:
Disconnect electrical, Position car on stands, remove rear wheels, drain oil = 45 min. Remove shift linkage, throttle & clutch cables, & exhaust (at the stub pipes) = 1 hour disconnect axles @ trans only = 15 min. Drop engine partway = 30 minutes Disconnect trans ground strap that you forgot = 2 minutes Finish engine drop & pull out rear = 5 minutes. Split engine from trans & remove clutch = 15 minutes install yoke & Lift onto engine stand (5 minutes & 1 hour finding someone to help lift it) Disassemble - depends on how cautious you are.... |
larss |
May 29 2014, 01:18 PM
Possibly "with the engine in the car" means the engine sitting in the rear boot... then its possible to lift the heads (IMG:style_emoticons/default/biggrin.gif)
/Lars S |
worn |
May 29 2014, 01:36 PM
Oops, brain fart. For some reason, I thought you were asking about doing it without splitting the case.... Yeah, the motor comes out--no way around that. Not unless you want to sawzall the body up and then weld it all back together again after. (IMG:style_emoticons/default/wink.gif) --DD Are you sure? Wouldn't want to try, but without the exhaust and valves you get more wiggle, and maybe the axles aren't in either. |
Dave_Darling |
May 29 2014, 04:45 PM
The heads will hit the suspension console long before they slide off the longer studs.
You can probably slide them off if you disconnect the engine and lower it ~6", but by that point you're only a couple of wires and cables from completely removing the engine from the car anyway. And it's a heck of a lot easier to deal with it on the bench than hanging halfway out of the engine bay. --DD |
Lo-Fi Version | Time is now: 27th September 2024 - 06:34 AM |
