> Phoenx trip, high temperatures
cpavlenko
post Jun 5 2014, 06:13 PM
Well, I'm driving my stock 71 1.7 from north AZ. To south Phoenix, and it's going to 108, or higher. My concern is heat and my engine. Never drove it with this type of hot weather. Should I have any concerns . (IMG:style_emoticons/default/confused24.gif)
Mblizzard
post Jun 5 2014, 06:29 PM
If you have not relocated the fuel pump to the front of the car you should be concerned about vapor lock.
Next check the operation of your thermostat to be sure it works correctly. If it does not work make sure the flaps are in the full cool position.
Last make sure your oil cooler is free of debris that could block air flow.
bdstone914
post Jun 5 2014, 07:07 PM
bdstone914
Do you have an oil temp gauge?
That is the only way you will know if the engine is getting too hot.
michael7810
post Jun 5 2014, 07:59 PM
I'm sure each engine is different. I would assume a stock system in good operating order would be OK. My 1911cc with carbs ran hotter than I liked when the temps were over 100F, freeway oil temp hit 250 a couple times. I since added an external oil cooler and switched to Joe Gibbs air-cooled oil and it runs 225F max. Feel free to shoot me a PM if you need any help while in PHX.
cpavlenko
post Jun 5 2014, 08:01 PM
Sooooo, what do I look for to c if thermostat is working the flaps correctly, and how are they powered? Or are they heat triggered.
Kirmizi
post Jun 5 2014, 08:17 PM
The thermostat expands as it heats up and moves the air flaps via the cable.
Keep your RPMs up on the highway to maintain good air flow and try to minimize any stop and go traffic.
cpavlenko
post Jun 5 2014, 09:48 PM
Thanks to all for the info, I'll b checking my thermostat in the morning, and checking everything else, flaps, cable, spring. The info was great to, thanks.
Dave_Darling
post Jun 5 2014, 10:05 PM
914 Idiot
BTW, a cooler full of ice (with a little water) and a dish towel are a lifesaver in that kind of heat. Soak the towel in the ice water, wrap it around your neck.
Vapor lock is not always a problem in that kind of heat. I did experience it in the Nevada desert, but I poured some water into the area above the pump and cooled it to where it ran again.
--DD
Mblizzard
post Jun 6 2014, 12:07 AM
QUOTE(cpavlenko @ Jun 5 2014, 06:01 PM) *
See this thread for a good write up on the flaps and thermostat.
crash914
post Jun 6 2014, 02:51 AM
its a mystery to me
when you travel, you should always carry a towel...just saying.
post Jun 6 2014, 07:43 AM
Ron and I traveled thru some of that weather a few years back. His vapor locked but neither his 6 or my 4 ran too hot. A towel is nice but I found something better. Rinse out an old spray bottle of "I can't believe it's butter" and refill with tap water. The sprayer atomizes super small droplets and feels like a mister.
cpavlenko
post Jun 6 2014, 08:06 AM
well the cable is broke at spring area, and I pulled #2 plug wire and got a piece of 1/8" tube for for drip system, and I moved the mechanizing cross bar back and forth. The flaps are in open cooling position. I could tell when the flaps were closed and open with the 1/8" tube. So at least I know the cooling flaps are open.
boxsterfan
post Jun 6 2014, 08:16 AM
914's are kewl
QUOTE(cpavlenko @ Jun 6 2014, 07:06 AM) *
You can go to your local bike shop and get a $5 standard derailleur cable to use as a replacement. That's what I did recently. Works great and the cable is actually just a bit thicker gauge than stock.
ww914
post Jun 6 2014, 08:20 AM
914 Convert
If your spring is in place, the flaps will default to the full open position, but I think you proved that to yourself.
Krieger
post Jun 6 2014, 10:15 AM
You could drive early in the am when its coolest.
Mblizzard
post Jun 6 2014, 10:47 AM
While a bit redneck, I often removed the engine deck lid to allow the heat to escape. Slotting your deck lid hinges makes it a quick operation. Just don't leave the stock bolts in place while you drive because they won't be there later!
SLITS
post Jun 6 2014, 11:12 AM
"This Utah shit is HARSH!"
QUOTE(76-914 @ Jun 6 2014, 06:43 AM) *
Mine vapor locked due to the location of the fuel pump and the air dump from the /6 exchangers. No, I haven't moved the fuel pump, but one of these days I will (when I pull the engine ... SS lines and pump up front.)
Air temps were in the 107 - 111 range. Oil temp ran about 220 with excursions to 240.
sbsix
post Jun 6 2014, 12:00 PM
only the lead dog enjoys a change in scenery...
I drove my six into the Santa Ynez Valley (over the mountains from SB) a couple of years ago and it went from 70 degrees to 105 degrees. There wasn't a good turnaround and by the time I could, my oil temp gauge hit 220+ and my oil cooler seals started leaking afterwards. My car doesn't like that high heat. My recommendation is take a quart of oil with you just in case.
relentless
post Jun 6 2014, 12:22 PM
At the very least you could remove the rain tray from the engine lid to get better air flow into the engine compartment.
Bob L.
post Jun 6 2014, 12:49 PM
QUOTE(crash914 @ Jun 6 2014, 03:51 AM) *
I see you have been reading the "Hitchhikers Guide"
Always remember - DON'T PANIC!
- Lo-Fi Version Time is now: 27th September 2024 - 04:54 PM
