tilt front side window?, advice please. |
1stworks |
Jul 11 2014, 08:48 AM
Member Group: Members Posts: 491 Joined: 31-March 13 From: colorado Member No.: 15,718 Region Association: None |
Anyone convert there small side triangular window to tilt?
I am ok with using plexiglass if need b. My car has ALL vents/defrost covered up and it would b nice to move some air through the car. Thanks |
Mike Bellis |
Jul 11 2014, 09:35 AM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Roll down the windows and take the top off... (IMG:style_emoticons/default/poke.gif)
1stworks |
Jul 11 2014, 10:12 AM
It's been hot here and you can really move some air with them. Thinking I'llgo to junk yard see what i can find. (IMG:style_emoticons/default/confused24.gif) The RS dash has it's downsides. ...... (IMG:http://www.914world.com/bbs2/uploads_offsite/i1315.photobucket.com-15718-1405095353.1.jpg) |
hblyle |
Jul 12 2014, 09:09 AM
Member Group: Members Posts: 64 Joined: 23-May 11 From: Huntington Beach Member No.: 13,110 Region Association: Southern California |
Might want to talk to these guys n see if they could make these for a 914 http://www.projectgla.com/store/products.php?65 |
JeffBowlsby |
Jul 12 2014, 09:19 AM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Those wing windows with the pivot lever latches were a problem for the VWs that had them because they were easy to open from the outside with a coat hanger. They were great if you had locked your keys in the car, but they also made it easy for the bad guys to get it.
Mike Bellis |
Jul 12 2014, 09:27 AM
Those wing windows with the pivot lever latches were a problem for the VWs that had them because they were easy to open from the outside with a coat hanger. They were great if you had locked your keys in the car, but they also made it easy for the bad guys to get it. Does that mean you actually lock your doors? (IMG:style_emoticons/default/confused24.gif) I don't lock mine ever. I figure if a thief wants it, locked door wont stop them. I don't leave valuables in the car. Leaving the doors unlocked may prevent additional damage to the car. Back to the first topic. It gets 90°-100°+ here in the summer. I leave the top on and the windows down and I get plenty of air flow in the car. In fact, I almost never take my top off... |
sixnotfour |
Jul 12 2014, 12:15 PM
914 Wizard Group: Members Posts: 10,525 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
here is what Kremer did...then you will have air flow at no speed..
Attached image(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 01:56 PM |
