914-6 Mufflers |
914-6 Mufflers |
patssle |
Aug 17 2014, 10:32 AM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I was under the impression that 911 2 in / 1 or 2 out mufflers would work for 914-6 cars. Am I wrong? I picked up a Dansk 2 in 2 out muffler that a friend let me borrow and it doesn't fit. The OD of my MSDS headers are 26.5 inches. The OD of the input flanges of the muffler are 27.75 inches.
I don't know what to do now! Everything I had read said 911 mufflers will work great. |
toolguy |
Aug 17 2014, 10:46 AM
Senior Member Group: Members Posts: 1,273 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Yes, early 911 and 914-6 are the same muffler body but OE 6's have a slightly different single outlet tube shape to conform to the single outlet hole in the stock 6 rear valance panel. . . . If yours doesn't see to fit, I'd suggest you loosen the connections to the heads , then try the muffler.
rgalla9146 |
Aug 17 2014, 12:00 PM
Advanced Member Group: Members Posts: 4,624 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I agree with Toolguy.
All "2in" mufflers have the same inlet locations. The issue is most likely the aftermarket headers. Loosen all fasteners and try again. Also the muffler hanger will be a good indication of where the headers have to go. If you don't have a hanger the one for 73-74 2.0s is very similar to a 914 6 and is an ideal substitute. |
patssle |
Aug 17 2014, 12:17 PM
If the exhaust is flush and sealed without any force from the muffler prying the exhaust outputs apart 1.25 inches....would loosening the exhaust and then re-tightening with the muffler forcing the ends apart possibly not let the exhaust seal fully against the heads?
I do have a muffler hanger that came extra with the car but I don't know what year it is and it does not line up to the exhaust bolt holes - the hanger bolt holes are 2-3 inches above the exhaust. |
GeorgeRud |
Aug 17 2014, 12:34 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
That muffler hanger looks to be for a 1.7 or 1.8 liter car, and won't fit the -6 muffler.
If you're not sure about the headers, give Martin at MSDS a call and he would know if there's any issue with the headers. He's a good guy and his stuff is top notch. obviously, you need to leave off the lower valance or cut a notch for the other outlet pipe from the muffler if it's two out (bullhorn style). A 'sport exhaust' muffler should exit under the later style rear valance without clearance holes. |
patssle |
Aug 17 2014, 01:29 PM
Marty responded to my email and gave me some tips - I'm going to give it a try this evening. Will post the results!
patssle |
Aug 29 2014, 06:14 PM
My exhaust did end up bolting fine after loosening the headers.
Per muffler hanger - are the 73-74 2.0s the only year/model that will work with /6 headers/mufflers? Which version is this reproduction on PelicanParts? (IMG:http://www.914world.com/bbs2/uploads_offsite/www.pelicanparts.com-10741-1409357679.1.jpg) PS. I have a 1.7/1.8 model muffler hanger and willing to trade for the early model! |
Dave_Darling |
Aug 29 2014, 06:24 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
That image looks like the 2.0 version, which is what you want. There are three versions, one for the 70-74 1.7/1.8, one for the 73-74 2.0, and one for the 75-76 1.8/2.0 .
--DD |
patssle |
Aug 29 2014, 07:08 PM
And the early 2.0 is the only one that will fit out of those 3...correct? The later 2.0 will not.
914Sixer |
Aug 29 2014, 07:14 PM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Correct, only the 73-74 2.0L will work.
patssle |
Aug 31 2014, 04:35 PM
I made my 1.7/1.8 muffler work with my /6 headers. Might not be original design but I think it worked out nicely. Couple dollars of nuts and bolts beats $65 for a new hanger.
worn |
Aug 31 2014, 06:39 PM
can't remember Group: Members Posts: 3,290 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I made my 1.7/1.8 muffler work with my /6 headers. Might not be original design but I think it worked out nicely. Couple dollars of nuts and bolts beats $65 for a new hanger. Exactly what I am planning! Spooky close. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 10:27 AM |
