Tailshifter, improving my tail shifter |
Mike1981 |
Nov 12 2014, 03:31 PM
Member Group: Members Posts: 232 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello Everyone
I was asking JRust about his Suby Conversion and how it shifts. He advised me to post a thread on here to get some advice. Well, here goes: I bought a 1970 914 with a tailshift 901 and a Suby Ej22 Motor Love the car except for the shifting. P.O. did a good job sorting the car out. However he needed to fabricate a custom linkage rod to allow for the suby engine. This has added to the vagueness in the linkage P.O. has replaced the bushings, I have performed a visual and they look good So far the only gear I can reliably find is 3rd 2nd is tough to find, sometimes I simply cannot find it and have to put it into 3rd lugging the car until it gets up to speed. Also when shifting into 2nd and 4th it feels like the rod is flexing before it slides into gear. 1st is rarely used but I can find it if I allow RPMs to decrease. 4th is OK 5th is OK I have accidentally put it in reverse grinding it (thinking it was 2nd) as well as when downshifting accidentally putting it in 2nd when I wanted 4th redline! owch! I've crawled underneath, the linkage has play, and even the end of rod going into the shifting arm would need material added to take up slop. Wondering what would be the best way to improve this? New Shifter springs/Short Shift? New rod/Linkage? Or leaning towards cable shift as I have read where the tailshifter will never be good? I have seen Kevin311's design and would like to do something like that if I could get some help on the plates. If anyone can get a hold of Kevin311 I would really like to get the drawing for the plates he fabricated for his shifter it looked very good and he extended an offer to help others. I have slowed down my shifting by grabbing the shifter with 3 fingers and feeling for the gears Also use the 1 second rule (Clutch in move lever out of 2nd inot neutral count 1 second into 3rd) this helps but becomes unmanageable when driving in heavy traffic Any Thoughts? |
mepstein |
Nov 12 2014, 08:03 PM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Subie trans, cable shift. Call Ian at coldwater
rhodyguy |
Nov 12 2014, 09:21 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Check the triple rolled pin under the inspection plate on the bottom rear where the linkage enters the trans. You'll prob need a new gasket and Drain lube first. I doubt a short shift kit and or stiffer springs will help. Have you ever cleaned the grease and gunk that can build up on the springs and the bottom side of the shifter assem?
Mike1981 |
Nov 13 2014, 07:05 AM
Thanks for the advice
I believe the inspection plate is the small downward facing plate at the rear of the trans with 4 bolts correct? I assume I will need to drain tranny oil to check this. I have not pulled the shifter for fear of misaligning the shifter and loosing all my gears Can I pull the shifter without disturbing the alignment? Thanks Mike Check the triple rolled pin under the inspection plate on the bottom rear where the linkage enters the trans. You'll prob need a new gasket and Drain lube first. I doubt a short shift kit and or stiffer springs will help. Have you ever cleaned the grease and gunk that can build up on the springs and the bottom side of the shifter assem? |
rhodyguy |
Nov 13 2014, 10:54 AM
the shifter for the tail shift linkage utilizes one of the ball cups on the front coupler. iirc, unbolt it from the center tunnel and it should lift out saving the current adjustment. while you're in there check the 1st/Reverse block out plate for wear, the contact edge should be straight (i have an 'as new' one and will post a picture of it later), and at the point on the lever where the plate makes contact for wear. if the ball cup bushing for the lever looks shoddy replace that as well. correct on the inspection plate location. there will be some residual gear lube after draining. be prepared
Dave_Darling |
Nov 13 2014, 11:01 AM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Pelican has a tech article on the subject: http://www.pelicanparts.com/techarticles/9...ift_improve.htm
The short version is, check the bushings and the wear points. There are a couple that are not obvious, like the reverse lock-out plate in the base of the gear shift lever. The Rennshift shifter is evidently a significant improvement over the stock piece, especially over a worn gear shift lever assembly. But it will only help so much if your bushings are worn severely or missing altogether. Side-shift conversions can help a bit more, but they are significantly more involved. Going to a cable-shift setup is even more involved, but it lets you do some fabrication and problem solving which is fun if you like that sort of thing. The Scooby trans with a cable shifter also sounds like an attractive idea, but that's even more work. --DD |
Mike1981 |
Nov 13 2014, 06:51 PM
Thanks everyone
This is really helping Mike |
Garland |
Nov 13 2014, 08:09 PM
Restoration Fanatic Group: Members Posts: 1,370 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Mike,
I have found this tool helpful when searchIng for info. http://www.google.com/coop/cse?cx=00240834...2%3Aajvfxschcgc Try "901 trans shifting" John |
Ben and Ralph |
Nov 13 2014, 11:32 PM
Ben Group: Members Posts: 110 Joined: 8-July 10 From: Los Angeles Member No.: 11,917 Region Association: Southern California |
install a bushing kit, check how round the sphere is at the end of the rear shift rod, and check how worn the gear shift lever is. I had to weld some globs on both and machine them back to the original shape. Going from 1st to 2nd is a task in any tailshift car, I personally double clutch from 1st to guide it into second.
Mike1981 |
Nov 14 2014, 07:32 AM
Thanks John...again
Mike, I have found this tool helpful when searchIng for info. http://www.google.com/coop/cse?cx=00240834...2%3Aajvfxschcgc Try "901 trans shifting" John |
Mike1981 |
Nov 14 2014, 07:33 AM
I thought I may have to add some material to shim up the linkage
Thanks Mike install a bushing kit, check how round the sphere is at the end of the rear shift rod, and check how worn the gear shift lever is. I had to weld some globs on both and machine them back to the original shape. Going from 1st to 2nd is a task in any tailshift car, I personally double clutch from 1st to guide it into second. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:30 AM |
