Hayward and Scott 914-6 Heat Exchangers, Fitment Issues |
bluhun |
Nov 13 2014, 10:00 PM
Member Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California |
I purchased a set of the Hayward and Scott heat exchangers for my 1975 3.2 liter conversion several months ago. The conversion was performed 5 years ago and designed around the Billy Boat heat exchangers and muffler system. I was not happy with the B&B system because of the inadequate flow of hot air it delivered, and decided to give the H&S system a try. Attached is a picture of the H&S heat exchangers.
Unfortunately, and not surprisingly, we encountered significant fitment issues with the H&S heat exchangers. First of all, the exhaust primaries would not bolt up with the cylinder heads without enlarging the bolt holes on the exhaust flanges. Not a big issue, just enlarge the holes. The hot-air exit tube on the exchangers needs to be extended by several inches to bolt up to the heater-control valves. The collector end of the exhaust would not mate up with the B&B muffler, necessitating the purchase of a standard 911 banana-type muffler. The most significant fitment issue, however, is that the system interferes with oil changes and exhaust-valve adjustments, requiring the exhaust to be removed in order to do an oil change or an engine service. We reluctantly decided to retain the B&B system for the car, and new heater-control valves did significantly improve the hot-air flow. All-in-all, this has been a very expensive lesson. The H&S exchangers come with 1-3/4" primaries and a 2" collector. The driver's-side comes with an O2-sensor bung installed. I am willing to sell them for considerably less than I paid for them ($2,900 including shipping). I will be posting an ad in the classified section. Attached thumbnail(s) |
r_towle |
Nov 13 2014, 10:18 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I know a guy who may want those...will point him at this thread.
For more airflow, look into the marine world for inline bilge fans. I recall they are 2 inch diameter, or maybe a bit larger. Fit inline in the front trunk so you can move more air. Work really well and run on 12 VDC. |
rick 918-S |
Nov 13 2014, 10:36 PM
Hey nice rack! -Celette Group: Members Posts: 20,680 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Is there a reason aftermarket HE never seem to be designed like the factory units? I don't get it. I have yet to here of a good result from aftermarket HE's.
PanelBilly |
Nov 13 2014, 10:40 PM
914 Guru Group: Members Posts: 5,840 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
We need to get these made by the 914Rubber team!
Mark Henry |
Nov 13 2014, 10:43 PM
I was expecting better quality than that. (IMG:style_emoticons/default/sad.gif)
Those welds and the way the box is attached suck. QUOTE The hot-air exit tube on the exchangers needs to be extended by several inches to bolt up to the heater-control valves. They may have been expecting you to use the stock /4 valve extensions? Fits the stock banana but not the B&B? I'd expect that one. Have to drop the exhaust for service??? (IMG:style_emoticons/default/blink.gif) No fuching way am I doing that everytime. Sounds like a poorly designed system to me. |
campbellcj |
Nov 13 2014, 11:05 PM
I can't Re Member Group: Members Posts: 4,574 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
It's a bummer that SSI, M&K, Dansk or some other manufacturer with the expertise to do this right has not done 914-6 stuff (maybe long ago but I mean now.) The market is just not there I guess.
Cairo94507 |
Nov 13 2014, 11:06 PM
Michael Group: Members Posts: 10,022 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I am so sorry to hear that! I had identified those as the most likely heat exchangers for my car. But as I am putting a 3.2 in my car I would face the exact same problems. Pulling the heat exchanger to change oil is not going to work for me. So it looks like I am back to my stock heat exchangers with heater valves that are in the best possible condition to make sure I get heat.
mepstein |
Nov 14 2014, 07:07 AM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I am so sorry to hear that! I had identified those as the most likely heat exchangers for my car. But as I am putting a 3.2 in my car I would face the exact same problems. Pulling the heat exchanger to change oil is not going to work for me. So it looks like I am back to my stock heat exchangers with heater valves that are in the best possible condition to make sure I get heat. If i had stock HE's, I would run them. Maybe you loose 10-20 hp at wot, doesn't matter, with your engine, you are still spinning the tires at will. factory fit is still best. NOS flapper valves are available for less than $200/pair. I would ceramic coat the he's. Thank you to the original poster for an honest review. |
scotty b |
Nov 14 2014, 07:20 AM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
I am so sorry to hear that! I had identified those as the most likely heat exchangers for my car. But as I am putting a 3.2 in my car I would face the exact same problems. Pulling the heat exchanger to change oil is not going to work for me. So it looks like I am back to my stock heat exchangers with heater valves that are in the best possible condition to make sure I get heat. Thank you to the original poster for an honest review. (IMG:style_emoticons/default/agree.gif) This kind of feedback will save several form wasting their money. It is a shame no one makes a good set of exchangers,. As noted, one would think the demand must not be there, BUT at least 2 companies thought there was enough demand to put out for the tooling to make these poor fitting sets, so how bad could it have been to make an authentic reproduction in S.S. (IMG:style_emoticons/default/confused24.gif) |
IronHillRestorations |
Nov 14 2014, 08:16 AM
I. I. R. C. Group: Members Posts: 6,759 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Bending SS tubing is the big issue, and that's why no one is jumping out there to make these.
scotty b |
Nov 14 2014, 09:30 AM
Bending SS tubing is the big issue, and that's why no one is jumping out there to make these. Plenty of companies make pre bent sections though. A good welder could make a jig, fab them up, clean up the welds and done. I see the biggest issue being properly stamping the heater shells. This would require either a hammer form and a LOT of manual labor hand hammering them, or making a set of dies for a XXXX-ton press and stamping them. Either way, it wouldn't be cheap, so the question is .....is there enough demand (IMG:style_emoticons/default/confused24.gif) |
sixnotfour |
Nov 14 2014, 09:46 AM
914 Wizard Group: Members Posts: 10,525 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Even made from mild steel with a ceramic coating they will outlast a 914...factory ones were painted outside only.
r_towle |
Nov 14 2014, 09:47 AM
A combined effort between a good tubing shop and someone like restoration design for stamping may make it a worthwhile thing to do....
fixer34 |
Nov 14 2014, 10:41 AM
Senior Member Group: Members Posts: 1,160 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
A combined effort between a good tubing shop and someone like restoration design for stamping may make it a worthwhile thing to do.... I'm in, but I don't have the facilities/skill to do it. I've been thinking about this for quite some time. Yea, stainless is nice, but mild steel and then get it coated would make it much easier to produce. The sheet metal heat exchangers (and the thru holes for the exhaust nuts) would be a little bit of work, but once you got the pattern done. Just look on the VIN registry-there are a lot of 'real' sixes still out there, plus a bunch of conversions. They can't all be in SoCal where you don't want/need heat so you can run headers. By the way, if anyone knows how to adjust the exhaust valves on a six WITHOUT removing the heat exchangers, or dropping the engine/trans slightly, I'm all ears. I've never been able to figure out how to get the valve covers off, let alone adjust the valves with removing them. |
rgalla9146 |
Nov 14 2014, 03:22 PM
Advanced Member Group: Members Posts: 4,624 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
A combined effort between a good tubing shop and someone like restoration design for stamping may make it a worthwhile thing to do.... I'm in, but I don't have the facilities/skill to do it. I've been thinking about this for quite some time. Yea, stainless is nice, but mild steel and then get it coated would make it much easier to produce. The sheet metal heat exchangers (and the thru holes for the exhaust nuts) would be a little bit of work, but once you got the pattern done. Just look on the VIN registry-there are a lot of 'real' sixes still out there, plus a bunch of conversions. They can't all be in SoCal where you don't want/need heat so you can run headers. By the way, if anyone knows how to adjust the exhaust valves on a six WITHOUT removing the heat exchangers, or dropping the engine/trans slightly, I'm all ears. I've never been able to figure out how to get the valve covers off, let alone adjust the valves with removing them. Turbo valve covers cannot be removed with the engine mounted, unless you trim them. Stockers, no problem. I've adjusted the valves without removing the heat exchangers, not easy but do-able . A lift makes it a lot easier switching from intake to exhaust. Best to remove the wheels and lay under the car with your feet extended toward the side opposite the bank you're working on. Rotating through the firing order will have you up and down many times. Or six times. Remove the plugs to ease turning the crank, (use a medium length 19mm wrench at the pulley). The ignition rotor and the marks on the crank pulley will tell you where you are. Later crank pulley ? AC pulley ? crank fire ? Remove the engine. OR use a long stick (chopstick ?) to feel each piston come to the top of its stroke, verify clearance at both valves, adjust away ! |
SLITS |
Nov 14 2014, 03:53 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
There is also the backside of the cam method.
GeorgeRud |
Nov 14 2014, 05:47 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Or simply adjust all the exhausts while under the car, the do the intakes from the top after the exhausts are done.
However, as easy as it is to drop the engine, it almost makes sense to drop the engine, adjust the valves, clean everything up, and reinstall! |
wndsnd |
Nov 14 2014, 07:52 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Maybe Chris could put a box around his headers for us......... John |
bigkensteele |
Nov 14 2014, 08:09 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I was expecting better quality than that. (IMG:style_emoticons/default/sad.gif) Those welds and the way the box is attached suck. QUOTE The hot-air exit tube on the exchangers needs to be extended by several inches to bolt up to the heater-control valves. They may have been expecting you to use the stock /4 valve extensions? Fits the stock banana but not the B&B? I'd expect that one. Have to drop the exhaust for service??? (IMG:style_emoticons/default/blink.gif) No fuching way am I doing that everytime. Sounds like a poorly designed system to me. Mark, I thought that you were contemplating removable clam-shells to work with Marty's headers. We PMed about it a while back. Is that off the table? |
wndsnd |
Nov 14 2014, 08:10 PM
What is the process for lowering the engine for valve adjustment if you use a pivoting mount like Patrick Motorsports?
Disconnect shifter and heaters and just drop the rear mounts? That seems a bit too easy. John |
Lo-Fi Version | Time is now: 27th September 2024 - 08:04 AM |
