WTB: 75 914 2.0L F.I. Throttle Cable Connecting Hardware, Throttle Cable Connecting Hardware F.I. 2.0L |
91422.7 |
Apr 2 2015, 06:02 PM
Newbie Group: Members Posts: 36 Joined: 8-October 14 From: Eugene, Oregon Member No.: 17,991 Region Association: Upper MidWest |
WTB: I realize this is pretty petty but I'm missing some pieces that is needed to attach my Accelerator cable to the F.I. body! This is a 1975 2.0L Engine with matching F.I.. I've attached some pics if that helps. If no one has these pieces laying around maybe you could direct me to a supplier! Thanks
Attached image(s) |
TheCabinetmaker |
Apr 2 2015, 07:16 PM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I have all the parts, but which ones specifically?
OK, I see you are missing two nuts and washers that mount the cable housing to that bracket it's sitting in. |
91422.7 |
Apr 2 2015, 07:48 PM
I have all the parts, but which ones specifically? OK, I see you are missing two nuts and washers that mount the cable housing to that bracket it's sitting in. Thanks for responding, I can come up with the nuts and washers you mentioned I'm sure at the hardware store but I DONT have the hardware to connect the end of the cable to the end bracket! Thanks |
TheCabinetmaker |
Apr 2 2015, 08:02 PM
The cable end attaches to the barrel clamp. It should have a small bolt that uses an 8mm socket (3mm bolt?) In the end of the barrel.
91422.7 |
Apr 2 2015, 08:53 PM
Thanks for the information, do you have those pieces? thanks
boxstr |
Apr 2 2015, 09:40 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
I have the pieces at CAMP 914. I will pull them off the shelf tomorrow, send an email and I van end pic to make sure we have the right stuff.
Craig at CAMP |
91422.7 |
Apr 2 2015, 11:25 PM
boxstr |
Apr 3 2015, 02:20 PM
Email sent.
Craig |
91422.7 |
Apr 4 2015, 08:28 AM
Curt and Craig thanks for your assistance! I found the piece I needed locally! Craig you had mentioned you thought you had one, if you have already mailed it, that's fine, I could always use an extra one! Let me know! Happy Easter....Roy
boxstr |
Apr 4 2015, 09:09 AM
I'll hang on to this one. It will probably be here when you need another one.
Craig at CAMP |
Lo-Fi Version | Time is now: 27th September 2024 - 12:14 PM |
