901 transmission internal failure |
john77 |
Feb 17 2016, 10:27 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
(IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1455769622.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1455769622.2.jpg) I was in third, accelerated hard and pop. Pulled the tranny and found a lot of metal debris. I have Dr Evil's rebuild DVD so I'm going to tear it down completely tomorrow and see how extensive the damage is. Looking through the side shift console mount hole at least two of the gears have completely chewed each other's teeth off. Anyone have any experience of what would cause this? And what other damage I should be looking for? Is there a point of no return where it makes more financial sense to buy another used 901 rather than try to rebuild it? Just trying to figure out what my options are. |
ConeDodger |
Feb 17 2016, 10:34 PM
Apex killer! Group: Members Posts: 23,758 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
It's extreme... (IMG:style_emoticons/default/blink.gif)
I bet those gear teeth took out some more stuff on the way out! (IMG:style_emoticons/default/sad.gif) |
914_teener |
Feb 18 2016, 12:13 AM
914 Guru Group: Members Posts: 5,245 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Doc would know better than me...holy cow...to shear all theeth off the gear?
Main output bearing let go and seized? |
0396 |
Feb 18 2016, 01:21 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
It's extreme... (IMG:style_emoticons/default/blink.gif) I bet those gear teeth took out some more stuff on the way out! (IMG:style_emoticons/default/sad.gif) Agreed, total trash. ..best used as a paper weight. Unless you simply don't have the funds for a good used one..... where do you think the debris went, all to the bottom vs contaminating the rest of the trans. .....simple answer. |
Porschef |
Feb 18 2016, 07:04 AM
How you doin' Group: Members Posts: 2,175 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
The fluid looks very fresh, any chance it was low?
Mark Henry |
Feb 18 2016, 07:17 AM
The fluid looks very fresh, any chance it was low? What??? Swepco didn't save ya (IMG:style_emoticons/default/stirthepot.gif) Doc would know better than me...holy cow...to shear all theeth off the gear? Main output bearing let go and seized? This is my first guess. I can't make out any rollers, but in that mess... (IMG:style_emoticons/default/unsure.gif) |
john77 |
Feb 18 2016, 08:25 AM
By the sound it made my guess is the chunks went everywhere and then some. The oil wasn't low, I replaced it and all the seals on the tranny about 6 months ago. It still had a slight drip from the speedo drive, but nothing major.
Funds aren't a problem, I'm just trying to figure out what my best option is to get it back on the road. |
76-914 |
Feb 18 2016, 08:43 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Seals? Case seals? Did you get your pinion depth set correctly?
914_teener |
Feb 18 2016, 09:06 AM
Seals? Case seals? Did you get your pinion depth set correctly? Oh...oh........ (IMG:style_emoticons/default/ar15.gif) |
john77 |
Feb 18 2016, 09:59 AM
r_towle |
Feb 18 2016, 10:51 AM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
looks like the bearing, or bearing housing got out of round.
Best way to go, get another core and rebuild from there. You have a hosed case. Yes, it could be fixed, but I dont see the point given we can still find cores. rich |
0396 |
Feb 18 2016, 10:57 AM
It's extreme... (IMG:style_emoticons/default/blink.gif) I bet those gear teeth took out some more stuff on the way out! (IMG:style_emoticons/default/sad.gif) Agreed, total trash. ..best used as a paper weight. Unless you simply don't have the funds for a good used one..... where do you think the debris went, all to the bottom vs contaminating the rest of the trans. .....simple answer. Are you sure your not running a big block with 500 hp in that baby. (IMG:style_emoticons/default/biggrin.gif) |
tomeric914 |
Feb 18 2016, 11:32 AM
One Lap of America in a 914! Group: Members Posts: 1,263 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Lo-Fi Version | Time is now: 27th September 2024 - 10:19 AM |
