cylinder spacers |
cylinder spacers |
type47 |
Mar 22 2005, 07:28 AM
barrel shims, whatever you want to call them.... these are used to obtain desired deck height. i thought there would be alot more options out there since this step has been emphasized as very important. i found some available in .010", .020", .030".... but of course, in my first measurement, i would need .025" on one of the cylinders (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) so just a couple of questions:
what are your sources of cylinder spacers? can you stack cylinder spacers? (i don't see why not, just want an expert to confirm) |
DNHunt |
Mar 22 2005, 08:02 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
I wouldn't stack them. 2 more interfaces to seal per cylinder. I had Rimco machine some for me. Course mine were like .140 caose of the different components. I'd call them.
Dave |
Joe Ricard |
Mar 22 2005, 08:32 AM
You can do it this way and save the wait. Find some aluminum sheet .025 thick and cut your own. I cut Rob Watsons .040 shims that way and they were very consistant. Use a gasket cutter. UNLIKE a machinist that would try to cut them on a lathe..... never get them all the same. Not to mention cost you an arm and a leg.
Jake Raby |
Mar 22 2005, 08:35 AM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I have every cylinder shim from .007 clear to .350 on the shelf... In increments of .010 and some increments at .005 for common sized shims.
DNHunt |
Mar 22 2005, 09:15 AM
There you go. Looks like Jake's got you covered! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Dave |
Type 4 |
Mar 22 2005, 09:23 AM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
If you need a custom size like .027 or such I can provide them.
I make them to your specs. |
nebreitling |
Mar 22 2005, 09:31 AM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
stacking them is pretty common, but i've heard of some people not wanting to use more than one. looks like steve or jake has you covered.
hey steve -- parts shipped. sorry for the delay, i've been behind on things the past week. |
rhodyguy |
Mar 22 2005, 10:16 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
how great was the dif on the big one as compared to the others? what is considered acceptable without there being some cause for concern? why would one cyl measurement be so much greater?
k |
type47 |
Mar 22 2005, 09:15 PM
i went back today and remeasured the deck. i tried to be over careful; checking and double-checking that was at TDC. i determined that the deck is .020" on 3 and .025" on 1 cylinder. so, if the desired deck is .055", looks like i'll be talking to jake..... there needs to be more procedure info, technical info and parts info on this. i'm sure this step is necessary on every engine, but i would think all the big parts web sites would offer cylinder spacers.
now i do happen to recall that in a certain type IV rebuild video, deck height procedure was missing (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) (and i bought the video just for that info....) |
Jake Raby |
Mar 22 2005, 10:19 PM
On that particular video the info was purposely left out to keep things simple for a first timer building a 100% stock non modified engine.... (other than the oil pump)
The video we are producing in the spring will have more of this type of info than anyone could ever want, so if some of it's boring- don't bitch! One of the articles I'm working on for my new technical portion of the aircooled technology site goes over deck height in vast detail.... In the mean time if you buy the shims from me I'll help you figure out what you need....... Most big warehouses don't stock the shims because they are a lot of work to make unless you build engines and have to have them.... |
Lo-Fi Version | Time is now: 27th September 2024 - 08:17 AM |
