Front hood latch rebuilding |
Jameel |
Mar 14 2016, 09:28 PM
Member Group: Members Posts: 98 Joined: 6-October 15 From: Iowa Member No.: 19,239 Region Association: None |
Anyone ever tried to rebuild their hood latch? My pin was knocked loose at some point, and I can't seem to get the spring tensioned properly, line up the latch, and get the pin pushed through it all. I think I can flip the short leg of the spring underneath with a needle nose plier, but the straight portion seems too short. The mechanism is sound, just having a hard time getting it put back together.
Mike Bellis |
Mar 14 2016, 11:10 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
unhook the spring from the lever. place the right side of the spring in the correct position (rotate it over). replace pin or through bolt. Use a flat head screwdriver to push the hook side of the spring back and around the lever.
Done! |
bandjoey |
Mar 14 2016, 11:14 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Lots of good used ones around. I think I have 3. If u don't fix yours $12 mailed to you. Pm me if you need to. (IMG:style_emoticons/default/beer.gif)
Jameel |
Mar 15 2016, 08:01 AM
unhook the spring from the lever. place the right side of the spring in the correct position (rotate it over). replace pin or through bolt. Use a flat head screwdriver to push the hook side of the spring back and around the lever. Done! You make it sound easy. I'll give it a try. I think the straight leg of my spring is too short though. I'll give it a shot. Lots of good used ones around. I think I have 3. If u don't fix yours $12 mailed to you. Pm me if you need to. (IMG:style_emoticons/default/beer.gif) Thanks! I'll keep it in mind if I fail. |
Lo-Fi Version | Time is now: 26th September 2024 - 09:46 PM |
