Gas Tank fitting threads, Thread size and pitch to chase threads |
North Coast Jim |
May 2 2016, 01:02 PM
Member Group: Members Posts: 328 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Two steps forward and one back. (IMG:style_emoticons/default/confused24.gif)
Hoping someone has seen this before and has the answer. While getting ready to run lines for the new Carb setup I'm replacing the in tank screen and blocking off the small FI return line. Seems the aluminum fitting threaded onto the large tank flange has decided to leave half it's threaded material imbedded into the male threaded gas tank fitting. Need to clean out the trapped material. Anyone have the thread particulars so I can locate a die to chase the threads or is there another way. Also looks like I'll need a female nut special for this case. Where to go for this item ?? |
cary |
May 2 2016, 03:26 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
M18 * 1.0
Nissan pick up spindle nut. Dorman 615-087 5 pk. |
North Coast Jim |
May 6 2016, 03:22 PM
M18 * 1.0 Nissan pick up spindle nut. Dorman 615-087 5 pk. If we ever run across one another in person remind me that I owe you a Beer !!! This worked wonders with the threads now restored and most of the aluminum removed. Now off to find the new replacement Special fitting nut I need for this application. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:24 AM |
