7x16 Fuchs narrow body tire choice, 205/50 or 205/55 for 7x16 Fuchs |
lonewolfe |
May 12 2016, 07:00 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
I have a set of 7x16 Fuchs from a 911 SC that I plan to put on my '72 narrow body car. I realize there may be some fender lip rolling and possible fender pulling needed. My question is how much more difficult will a 205/55 be compared to a 205/50 tire for the rear fender clearance. Has anyone tried fitting both these sizes? The appeal of the 55 series tire is it's very close to the original tire diameter and will have a more accurate speedo reading and a little lower RPM's on the highway. Any thoughts on this.
I have done a number of searches but not found anything addressing this question. |
mepstein |
May 12 2016, 07:04 PM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
It's not a question of if you will have to roll, pull & modify your fenders, it's how much. So you might as well just use the tire you want.
JRust |
May 12 2016, 07:15 PM
914 Guru Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I ran 215/45's on 7x16" fuchs. Only rolled lips & no fender pulling. I did have my rear camber in a bit too. Was tight but fit
somd914 |
May 12 2016, 07:19 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
lonewolfe |
May 12 2016, 07:24 PM
DBCooper |
May 12 2016, 07:43 PM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
lonewolfe |
May 12 2016, 07:51 PM
I ran 215/45's on 7x16" fuchs. Only rolled lips & no fender pulling. I did have my rear camber in a bit too. Was tight but fit Same here, but 215/50's on 911 Fuchs. Rolled lips and a bit of pulling, tight but no rubbing. Interesting! I've not even considered a 215/50. Do you have any pictures you can post? |
DBCooper |
May 13 2016, 04:31 PM
Not many, apparently, I only found this, post number three in this thread: http://www.914world.com/bbs2/index.php?showtopic=274385
If you're thinking sevens then the rest of that thread may be interesting too. |
lonewolfe |
May 14 2016, 01:24 AM
Not many, apparently, I only found this, post number three in this thread: http://www.914world.com/bbs2/index.php?showtopic=274385 If you're thinking sevens then the rest of that thread may be interesting too. Thanks DB! |
somd914 |
May 14 2016, 06:03 AM
Downside of 215/50 and 215/45 is a limited tire selection these days, but they are still out there.
tomrev |
May 14 2016, 06:18 AM
Member Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None |
I wanted to lower the car without too much camber change, and like the lighter weight as well, so used 205/45/'s with my 16 by 7 fuchs. Able to run 1 deg. neg. camber in back, with no fender pulling, and just rolled inner lip. Ride is firm, but fine, and the size/look suits me.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 12:47 PM |
