transmission filler |
dflesburg |
Oct 28 2016, 07:25 AM
Senior Member Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
Thought I would share this with you.
I made a transmission filler last night because when replacing the clutch in my gti I felt new gear oil was in order. After refilling many 914 transmissions over the years I know what a pain it is. Here is what I did using one gallon plastic garden sprayer I cut the nozzle a couple inches from the handle and attached about 6 inches of silicone hose with a small band clamp. (got it off my old hand oil pump line. then I put the gear oil in and pumped it up. duct taped the trigger open and let it fill up.. worked great. |
Kansas 914 |
Oct 28 2016, 07:32 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
Thought I would share this with you. I made a transmission filler last night because when replacing the clutch in my gti I felt new gear oil was in order. After refilling many 914 transmissions over the years I know what a pain it is. Here is what I did using one gallon plastic garden sprayer I cut the nozzle a couple inches from the handle and attached about 6 inches of silicone hose with a small band clamp. (got it off my old hand oil pump line. then I put the gear oil in and pumped it up. duct taped the trigger open and let it fill up.. worked great. Brilliant - (IMG:style_emoticons/default/aktion035.gif) |
Phoenix-MN |
Oct 28 2016, 08:03 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
stugray |
Oct 28 2016, 08:09 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
eyesright |
Oct 28 2016, 10:01 AM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
Now THAT is really good! And no wonder your tranny and axles are so clean too. |
yeahmag |
Oct 28 2016, 10:38 AM
Advanced Member Group: Members Posts: 2,435 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Is that an electronic speedo setup?
dflesburg |
Oct 28 2016, 11:20 AM
so the idea behind the one I made was, put 2.5 quarts of gear oil in the container, pump it up, lock the trigger and eat dinner, when dinner is done, the trans is full.
Phoenix-MN |
Oct 28 2016, 11:39 AM
MartyYeoman |
Oct 30 2016, 05:03 PM
Senior Member Group: Members Posts: 1,525 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Now THAT is really good! And no wonder your tranny and axles are so clean too. I do similar funnel idea, except with a slightly longer tube and run it out through the right rear wheel well just behind the tire. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:49 PM |
