Removing the front control arms, Any helpful hints? |
chris914 |
May 2 2005, 12:31 AM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
I've read all the posts on removing the bushings from the front control arms.
Does anyone have any helpful hints for removing the front control arms from the car? The Haynes manual seems pretty straight forward. Also, is there anyone in San Deigo who has the turbo tie rod wrench I can burrow? :-) |
Jeroen |
May 2 2005, 04:17 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
First (if you haven't already) the strut from the a-arm (at the ball joint)
At the back, remove the t-bar adjuster bolt Then, right next to it is a bolt that holds the a-arm to the x-member At the front, remove the protector cap (allen bolt) Then remove the two bolts left and right of the a-arm, which hold it to the chassis support the a-arm with a jack or sumptin' pull it out towards the front of the car |
rhodyguy |
May 2 2005, 08:00 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
you may find it near impossible to get the a-arms out of the cross member and the out of the rear bushing retaining/cradling piece. if you remove the 2 bolts that hold the rack to the crossmember the whole thing will lower in one piece.
k |
Lo-Fi Version | Time is now: 27th September 2024 - 05:57 AM |
