Ignition switch wiring harness connector 914-6/911, What holds it in? Anything? |
mskala |
Jun 3 2017, 09:16 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
I have a flaky ignition switch. Some accessories work only with key wiggled in
certain place. So, it looks like there is enough room to replace the electrical part from behind, once fuse panel is out of the way. But what's holding the harness connector on the switch? I can't seem to pull it off and the new one clearly doesn't have any tangs or anything. |
JeffBowlsby |
Jun 3 2017, 09:35 AM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have a flaky ignition switch. Some accessories work only with key wiggled in certain place. So, it looks like there is enough room to replace the electrical part from behind, once fuse panel is out of the way. But what's holding the harness connector on the switch? I can't seem to pull it off and the new one clearly doesn't have any tangs or anything. The clamping pressure of the wire terminals is all, pretty typical. |
mskala |
Jun 3 2017, 09:47 AM
I have a flaky ignition switch. Some accessories work only with key wiggled in certain place. So, it looks like there is enough room to replace the electrical part from behind, once fuse panel is out of the way. But what's holding the harness connector on the switch? I can't seem to pull it off and the new one clearly doesn't have any tangs or anything. The clamping pressure of the wire terminals is all, pretty typical. I think I'll need a small channel-lock plier to really pull then. Thanks |
mskala |
Jun 3 2017, 07:56 PM
Also without one of these flexi-drivers you're toast getting at the top screw.
Lo-Fi Version | Time is now: 26th September 2024 - 09:47 PM |
