Fuchs Numbering Question, Numbering mistake (or mine)? |
BeatNavy |
Dec 21 2017, 04:29 PM
Certified Professional Scapegoat Group: Members Posts: 2,933 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Alright Fuchs experts. I picked up a set of 6x16 Fuchs yesterday. I got them home and took a closer look at them, as I wanted to validate that they were genuine (again). One of them was really faint, but I finally found my little fox friend on all four of them. All good.
In that process I noticed that the one wheel with the faintest fox seemed to have a discrepancy. The part numbers on all wheels show 911 361 020 43 as in the first pic below, which I am pretty sure corresponds to 6x16 on a '84 911 (all black). But the size number stamped on them, which is what I assume is what's in the second picture below, shows "6 J 15" (not 16). All the rest of the wheels show "6 J 16" like in the last picture. All p/n's match, and best I can measure the physical dimensions are the same on all the wheels. Is this a factory mistake or am I making a bad assumption or other stupid error? Probably the latter, as I haven't met my daily quota yet. (5-lug) Fuchs newbie out. |
mb911 |
Dec 21 2017, 04:36 PM
914 Guru Group: Members Posts: 7,159 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
That is strange..
914Sixer |
Dec 21 2017, 04:40 PM
914 Guru Group: Members Posts: 8,988 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Size is cast into wheel. Are you sure the diameter of wheel is 16" ?
JOEPROPER |
Dec 21 2017, 04:52 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
stand them up next to each other.
Larmo63 |
Dec 21 2017, 04:57 PM
Advanced Member Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
They don't all look identical as far as physical dimensions? (IMG:style_emoticons/default/chair.gif)
BeatNavy |
Dec 21 2017, 04:59 PM
BeatNavy |
Dec 21 2017, 05:03 PM
They don't all look identical as far as physical dimensions? (IMG:style_emoticons/default/chair.gif) They do look all identical (IMG:style_emoticons/default/chair.gif) Go drive your six, Lawrence (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/confused24.gif) |
theer |
Dec 21 2017, 05:13 PM
Senior Member Group: Members Posts: 681 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Try measuring the circumference: Put a string around the inside of the lip, where the bead of the tire will sit. Compare the "15" circumference to one of the 16's. If the same measurement, then at least you know the same size tires will fit...
Maybe the 16's are marked wrong? |
JOEPROPER |
Dec 21 2017, 05:14 PM
Try measuring the circumference: Put a string around the inside of the lip, where the bead of the tire will sit. Compare the "15" circumference to one of the 16's. If the same measurement, then at least you know the same size tires will fit... Maybe the 16's are marked wrong? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
cal44 |
Dec 21 2017, 05:30 PM
Member Group: Members Posts: 165 Joined: 8-October 09 From: Encinitas, Ca. Member No.: 10,910 Region Association: Southwest Region |
Please explain "all black". Should only be the center spokes black unless someone changed things.
BeatNavy |
Dec 21 2017, 05:35 PM
Please explain "all black". Should only be the center spokes black unless someone changed things. They came from the factory like this: (IMG:http://www.914world.com/bbs2/uploads_offsite/pro.typepad.com-17042-1513899307.1.jpg) Am I correct that the "6 J 15" (or 16) should reflect the size? I just stood them all up against each other on a table, and they all seem to match. |
bigkensteele |
Dec 21 2017, 06:34 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I think it is a factory mistake. Kinda like those double stamped pennies that everyone used to look for because they would be worth millions.
The last picture is definitely a 6x16. |
mepstein |
Dec 21 2017, 06:39 PM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
There are a lot of mistakes on Fuchs. Especially the 6x16’s when they were getting cranked out by the thousands. 15’s look very different on the front lip from 16’s.
Congrats on the wheels. It’s hard to go wrong with Fuchs. |
BeatNavy |
Dec 21 2017, 08:00 PM
Thanks, fellas. I'm pretty stoked to have them. They were a Christmas present. To myself. Now there's a 5-lug conversion in my future, so I'll probably need to call Eric at PMB. May have to be a Valentine's present. To myself... (IMG:style_emoticons/default/wub.gif)
Larmo63 |
Dec 21 2017, 08:11 PM
They don't all look identical as far as physical dimensions? (IMG:style_emoticons/default/chair.gif) They do look all identical (IMG:style_emoticons/default/chair.gif) Go drive your six, Lawrence (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/confused24.gif) I just got back from driving it all over. Thanks. Now go put those wheels on your car. (IMG:style_emoticons/default/smile.gif) |
porschetub |
Dec 21 2017, 09:11 PM
Advanced Member Group: Members Posts: 4,725 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Alright Fuchs experts. I picked up a set of 6x16 Fuchs yesterday. I got them home and took a closer look at them, as I wanted to validate that they were genuine (again). One of them was really faint, but I finally found my little fox friend on all four of them. All good. In that process I noticed that the one wheel with the faintest fox seemed to have a discrepancy. The part numbers on all wheels show 911 361 020 43 as in the first pic below, which I am pretty sure corresponds to 6x16 on a '84 911 (all black). But the size number stamped on them, which is what I assume is what's in the second picture below, shows "6 J 15" (not 16). All the rest of the wheels show "6 J 16" like in the last picture. All p/n's match, and best I can measure the physical dimensions are the same on all the wheels. Is this a factory mistake or am I making a bad assumption or other stupid error? Probably the latter, as I haven't met my daily quota yet. (5-lug) Fuchs newbie out. Hi Rob ,good score ,Hans must have had too many Becks the night before (IMG:style_emoticons/default/rolleyes.gif) ,the 6x16 has a noticeable flat area from the black centre to the rim edge...hard to miss. These wheels will be hard to find as the supply will dry up eventually due to there popularity on 911 914 and people buying them for the centres only to make 3 piece wheels using BBS barrels. |
eitnurg |
Dec 22 2017, 01:28 AM
Country Member Group: Members Posts: 150 Joined: 31-December 02 From: Nairobi Member No.: 62 Region Association: None |
But the size number stamped on them, which is what I assume is what's in the second picture below, shows "6 J 15" (not 16). All the rest of the wheels show "6 J 16" like in the last picture. All p/n's match, and best I can measure the physical dimensions are the same on all the wheels. It’s a factory mistake. I had one once: by coincidence it was adjacent to the fitted tyre size (205/55 R 16) and would have made a good photograph. Unfortunately its undoubted rarity did not translate into increased value, much as I tried. |
Dave_Darling |
Dec 22 2017, 01:31 AM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Am I correct that the "6 J 15" (or 16) should reflect the size? You are correct. The 6 is the width in inches, and the 15 is the diameter in inches. The J refers to the safety bead in the wheel which is supposed to keep the tire from completely departing the vehicle even if it no longer is pressed against the rim by air pressure. --DD |
Lo-Fi Version | Time is now: 26th September 2024 - 09:46 PM |
