High Amp Alternator upgrade, who has made the change? |
malcolm2 |
Feb 5 2018, 08:30 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I found McMark's thread on nice upgrade from a few years back.
It was not a step by step, I don't remember seeing much how-to or the final results on that thread. But my Alt died this weekend, so I thought I would research making an upgrade. Is there a nice step by step out there somewhere? Clark |
malcolm2 |
Feb 5 2018, 11:15 AM
I found a very old thread. I do remember Pete doing this. It was started a year before I had my car ready to drive, so I guess I did not put it in my memory bank.
http://www.914world.com/bbs2/index.php?s=&...t&p=1745884 Looks like it has been a year since the thread has had any buyers. And he has not been online for a month. Anyone want to comment on how his rig works? I have PM'd and emailed him to see if he is still actively making these. No wonder I could not find the thread yesterday. Pete used the MEMBER VENDOR page..... maybe like he was supposed to. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) But now it is lost. |
Mikey914 |
Feb 5 2018, 12:47 PM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
From what I've heard they worked well. If you upgrade to heated seats or anything else that takes some juice it's a no brainer.
DRPHIL914 |
Feb 26 2018, 10:36 AM
Dr. Phil Group: Members Posts: 5,808 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
have you figured out what you are going to do with this? did you go with a set up like Mcmarks or the 160amp one?
malcolm2 |
Feb 26 2018, 10:44 AM
At my urging, McMark started another Alternator thread and I have been adding to it. He just wanted to let us know what he did.
http://www.914world.com/bbs2/index.php?sho...=324239&hl= He also talked about getting the 1979 VW bus 70 amp alternator. I liked that idea, hoping it would bolt right up. So I bought one and started researching. Samba has some very good stuff too. But VW only put this alt on as a special camper option, so there aren't many. 912 uses the same ALT. But again, very few were made. It does bolt right up, but there are lots of little things that might be needed and I have found thanks to samba.... air intake elbow to fit the fan housing and the ALT, New wire harness with protection from the heat, a fan on the pulley, cooling tin and plastic ring changes. There are a few vendors that have the 160amp Mechman unit, but they are discontinued too. When my 70 amp ALT arrived the shaft had poked thru the box and damaged something inside. The replacement is on backorder 'til April. |
DRPHIL914 |
Feb 26 2018, 11:04 AM
thanks for the info- I now see all the threads relating to this- I pulled mine as I was cleaning and refreshing the motor and tin- my alternator is a 50 amp, not 55 so its an earlier one someone must have put on it, so my new tin piece I got from Bruce Stone does not fit. my charging was fine, I don't run fancy stuff but might go with the HID or LED head lights, not sure which one - I may just put this one back in for now and use the old ring with the plastic ring - just the boot I bought is too small fro the shroud opening as I stated in the other thread too. so I am not sure which way to go there. its crazy how many of these are now discontinued.
malcolm2 |
Feb 26 2018, 11:09 AM
I think it was Ratwell that said the internal parts get discontinued first. The 70amp one was no longer available new after 1999.
914Sixer |
Feb 26 2018, 01:59 PM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Sellers on Ebay have stock alternators that have been upgraded. Cost is in the $250 range.
malcolm2 |
Feb 26 2018, 02:29 PM
Sellers on Ebay have stock alternators that have been upgraded. Cost is in the $250 range. True. They will make you one at 400 or more amps if you want. The one I got from CARID cost $68, IIRC with a $30 core charge. and I knew it was original equipment on a TIV engine. With the wire harness coming out of the rear and the unit being mounted where it almost touches the 350 *F cylinder head and has very specific mounting brackets I did not want to be cutting and drilling a $250 alternator and then hope I could make it fit and not melt the harness. |
Lo-Fi Version | Time is now: 27th September 2024 - 12:16 PM |
