solid or hydraulic lifters, how do I set hydraulic lifters ? same as solids but at 0 instead of 6 |
Rogersrest |
Apr 21 2018, 09:02 AM
Newbie Group: Members Posts: 1 Joined: 20-April 18 From: Hawaii Member No.: 22,056 Region Association: None |
I just got a 1976 -4 cylinder it has a couple of valves that are loud . I adjusted them the same as my 72 VW bus at 6 . now it wont run it pops and wont start. I was reading the forum and I think I might have hydraulic lifters. would I set them in the same way as the bus or is there another procedure that I should use. rogersrest
iankarr |
Apr 21 2018, 10:20 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,512 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
First, you should confirm if the lifters are hydraulic by removing at least one. You can also do a down and dirty test by pulling back on the rocker to apply force on the pushrod. If it feels springy, you probably have hydraulic lifters.
If they ARE hydraulic, set to zero lash and then tighten 1/2 turn more. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:08 AM |
