Wiper Assembly Replacement |
MiniStevieG |
Feb 26 2019, 01:15 AM
Member Group: Members Posts: 179 Joined: 25-January 19 From: Dallas, TX Member No.: 22,827 Region Association: Southwest Region |
I’ve gotten everything else in working order now and I’m down to my final electrical issue before I can pass inspection. So my wipers haven’t worked since I bought the car and before I get to the engine swap I’m going to address this. To the the naked eye the assembly appears to be rusted frozen.
Looks like there’s no other way to get that assembly out other than removing what I think is the heater box in front of it. I’ve read that removing that box blocking the assembly is a real bigger and I’m looking for alternate suggestions before I start digging into it. Also I’m curious what relays and fuses might be related to the wiper assembly. Any suggestions? |
914Sixer |
Feb 26 2019, 08:16 AM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
No way around it, blower box has to come out to work on wipers.
Mark Henry |
Feb 26 2019, 09:17 AM
The rubber isolator mount is hidden and you have remove the nut or you'll break it.
Mark Henry |
Feb 26 2019, 09:23 AM
When it's out you could mod the arms (bend) and reclock the linkage to make the wipers park on the opposite side. There's a how to on pelican.
mepstein |
Feb 26 2019, 09:30 AM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Mark Henry |
Feb 26 2019, 09:41 AM
When it's out you could mod the arms (bend) and reclock the linkage to make the wipers park on the opposite side. There's a how to on pelican. Noooooo (IMG:style_emoticons/default/lol-2.gif) That's what I said when I almost did it back in the day. But at the time I didn't do it because it's wrong...I said "Noooo" because it was way too much work. |
914Sixer |
Feb 26 2019, 10:46 AM
Mounting isolator nut is on the inside of car behind the speedometer.
Rob-O |
Feb 26 2019, 10:47 AM
Senior Member Group: Members Posts: 1,253 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
I thought gas tank has to come out to get the fresh air box out. Is that not right? I swear I removed the tank when I did it. Maybe it was just I was planning on pulling the tank anyways...
Lo-Fi Version | Time is now: 27th September 2024 - 12:56 PM |
