WTB > 914-6 Air Filter Housing |
E911 |
Apr 25 2019, 09:58 AM
Newbie Group: Members Posts: 5 Joined: 6-April 19 From: Frozen Tundra Member No.: 23,014 Region Association: Northstar Region |
Looking for a correct and complete air filter housing for a six please.
Thank you- Richard |
tailwind22 |
Apr 25 2019, 10:39 AM
Member Group: Members Posts: 89 Joined: 7-November 17 From: Moses Lake, WA Member No.: 21,583 Region Association: Pacific Northwest |
For sure one of the Holy Grail used part finds for a 6!
E911 |
Apr 25 2019, 12:02 PM
I figured as much but also assuming this is a good place to ask.
Mike Fitton |
Apr 25 2019, 01:33 PM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
Start by buying a good main piece they are all the same, then start your search for the correct snorkel that faces to the left of the fan. Here are 2 nice plastic boxes on the Samba:
https://www.thesamba.com/vw/classifieds/det....php?id=2142435 https://www.thesamba.com/vw/classifieds/det....php?id=1473294 |
rgalla9146 |
Apr 25 2019, 02:11 PM
Advanced Member Group: Members Posts: 4,624 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
How original do you need to be ?
there are differences metal nipple for breather hose metal studs for wing nuts recesses for cold start enrichment plumbing metal strap to support hose connecting enrichment rails. Attached thumbnail(s) |
johnhora |
Apr 25 2019, 02:22 PM
Senior Member Group: Members Posts: 873 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
I have one available if you're looking to spend a lot less than $400+ for one that is not correct anyway.
The one I have is a plastic air box from the 911 MFI...it is the same except that it would have to be drilled for the Weber carbs vent tube holes(not a big problem at all). The one I have left is the second one in the pictures and will work fine. Just attache a snorkel. I have a metal not correct short snorkel if needed. And of course you will need the Weber metal connector bases and clips. Check it out here: http://forums.pelicanparts.com/porsche-911...rs-housing.html |
johnhora |
Apr 25 2019, 02:28 PM
How original do you need to be ? there are differences metal nipple for breather hose metal studs for wing nuts recesses for cold start enrichment plumbing metal strap to support hose connecting enrichment rails. (IMG:style_emoticons/default/agree.gif) If you are going for the real 914-6 one ...this one rgalla9146 posted is the correct one! There are plenty of imitations...like the one I posted...it has the plastic vent tube...and no weber vent holes. It took me two years to find a correct snorkel that wasn't a gazillion $$$$. You just have to be patient for the real stuff. |
E911 |
Apr 25 2019, 02:35 PM
Thanks for the replies and advice... I'd like to find a correct / original unit rather than a bitsa solution from a 911 application. There seems to be a lot of confusion on what's correct and what's not.
johnhora |
Apr 25 2019, 02:55 PM
Richard.....is this for a real 914-6?
Porsche Doc |
Apr 25 2019, 03:03 PM
HillBilly Member Group: Members Posts: 93 Joined: 11-December 04 From: Knoxville,TN Member No.: 3,265 Region Association: None |
I have a real one $500 + shipping
E911 |
Apr 25 2019, 03:13 PM
E911 |
Apr 25 2019, 03:16 PM
gereed75 |
Apr 25 2019, 05:06 PM
Senior Member Group: Members Posts: 1,286 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
There was one at Hersey. Complete including buckets in decent shape. Was asking $500. Anyone know who that was?
Porsche Doc |
Apr 25 2019, 06:29 PM
Porsche Doc |
Apr 25 2019, 06:33 PM
E911 |
Apr 25 2019, 07:29 PM
johnhora |
Apr 25 2019, 09:12 PM
Yes that is a 911 MFI unit that fits the 72-73 with plastic intake stacks.. It has been cut and plastic removed between the round stack openings on the underside possibly to accommodate carbs. Also the snorkel is an early 911 all metal one. Works but faces the wrong direction for a 914-6. As mentioned rgalla9146 posted a correct 914-6 one. Maybe he has some more pictures....I have some some where just can't find right now. The one rgalla9146 has pictured has the metal vent tube...on the bottom rear...cold start fuel rail inlets on the top rear corners...they extend into the interior and have little spray holes over each carb hole...yes when cold the fuel system dumped raw fuel into the whole plastic housing...talk about back fire flame outs....this was just like the early 911 all metal housings. Such crazy stuff going on and just some more of the unique parts for the 914-6. The 69-70 911T one is similar with a different snorkel. |
E911 |
Apr 26 2019, 06:03 AM
Thank you for the confirmation!
horizontally-opposed |
Sep 5 2021, 04:48 PM
Advanced Member Group: Members Posts: 3,443 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Lo-Fi Version | Time is now: 27th September 2024 - 08:43 AM |
