Rotating CV Joints |
troth |
Jun 21 2019, 09:27 AM
Member Group: Members Posts: 153 Joined: 17-August 16 From: CT/WA Member No.: 20,305 Region Association: None |
One of my CVs has been clicking lately. So I pulled them out while changing the clutch.
Definitely some putting in there, but I’m wondering if I can get away with just repacking and rotating them. My question is which way do you usually rotate them? Inside to outside, left to right, or both? Is it just the inner race that needs to move or the whole assembly? Any rule of thumb for when new ones are definitely necessary? |
tazz9924 |
Jun 21 2019, 12:05 PM
Senior Member Group: Members Posts: 716 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
One of my CVs has been clicking lately. So I pulled them out while changing the clutch. Definitely some putting in there, but I’m wondering if I can get away with just repacking and rotating them. My question is which way do you usually rotate them? Inside to outside, left to right, or both? Is it just the inner race that needs to move or the whole assembly? Any rule of thumb for when new ones are definitely necessary? usually if they start to click i replace them. That would indicate to me the clearances are larger than allowable and the joint is done. Maybe thats not the case but a set of beetle cvs cant be that much |
Mark Henry |
Jun 21 2019, 01:12 PM
Run your finger through the bearing grooves, if you feel a divot it's done.
You can flip them, but CV's is such a sucky messy job I only use prefect used or new. |
76-914 |
Jun 21 2019, 01:36 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Right to left/left to right (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 27th September 2024 - 10:52 AM |
