PMO Watershield Nut Size? |
defianty |
Aug 28 2019, 02:49 PM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
It appears they're not metric and therefore I'm lost (IMG:style_emoticons/default/laugh.gif)
Ideally I'd like to get some wingnuts but M5 are too small and M6 too big. Does anyone know the correct size? Thanks. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.postimg.cc-6621-1567025383.1.jpg)[/ur |
jd74914 |
Aug 28 2019, 05:16 PM
Its alive Group: Members Posts: 4,796 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
What's the thread major diameter? Likely a 10-24 if M6 is a little too big.
defianty |
Aug 29 2019, 01:16 AM
What's the thread major diameter? Likely a 10-24 if M6 is a little too big. @jd74914 My vernier caliper says 0.206". Thank you. |
defianty |
Aug 29 2019, 04:47 AM
A bit more research and with the help of an engineering friend we've found that the thread is UNC 12-24. My chances of finding a wingnut in that size in the UK are going to be slim. (IMG:style_emoticons/default/laugh.gif)
jd74914 |
Aug 29 2019, 05:24 AM
Wow-didn't even consider that since almost no one in the US uses #12 screws either. (IMG:style_emoticons/default/screwy.gif)
defianty |
Aug 29 2019, 06:33 AM
I've managed to find a source in the UK. They're made to order though so I'll just have to wait a couple of weeks. Fortunately they weren't expensive.
sixnotfour |
Aug 29 2019, 07:49 AM
914 Wizard Group: Members Posts: 10,525 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Attached thumbnail(s) |
Mark Henry |
Aug 29 2019, 08:38 AM
Problem is wing nuts will back off from vibration, that's why they come with nylocks.
I'd use some light duty loctite (purple, loctite 222) on the wingnuts so they won't get loose all the time. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:11 PM |
