Fuel Tank, Hole size & Bolt Pattern?, Help..I'm making a few through the hood GT Style Fuel Caps |
ValcoOscar |
Jun 8 2020, 03:39 PM
Garage Life Group: Members Posts: 2,468 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
I have the necks & caps but need to make some flanges and gaskets.
Do any of you know Hole Dia & Bolt Circle dims? TIA Oscar |
bob164 |
Jun 8 2020, 04:02 PM
Member Group: Members Posts: 97 Joined: 10-February 18 From: SoCal Member No.: 21,877 Region Association: Southern California |
Oscar,
I will measure mine in a few minutes, or I can bring over my filler neck to make a template if you would like. Bob |
ValcoOscar |
Jun 8 2020, 04:04 PM
bob164 |
Jun 8 2020, 04:40 PM
Oscar,
There are 8 evenly spaced holes (45 degrees apart) Bolt circle measures 3.224" dia. Bolt hole diameters measure 0.234" (with paint on the ID of the holes of my filler neck). The opening of the tank measures 2.808". The gasket surface OD measures 3.910" I measured twice, if you want me to bring the tank and filler neck over to transfer the pattern let me know. Bob |
bdstone914 |
Jun 8 2020, 05:03 PM
bdstone914 Group: Members Posts: 4,673 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@ValcoOscar
' date='Jun 8 2020, 03:04 PM' post='2823320'] [quote name='bob164' post='2823319' date='Jun 8 2020, 03:02 PM'] Oscar, I will measure mine in a few minutes, or I can bring over my filler neck to make a template if you would like. Bob [/quote] Please Bob...I have a spare tank in storage but it's 8-10 boxes deep and behind extra trans. Let me know...thx Oscar [/quote] I measure 82 mm bolt circle and 70 mm hole size. Measured off of a tank. |
ValcoOscar |
Jun 8 2020, 05:06 PM
THANK YOU....I think this info will work.
mb911 |
Jun 9 2020, 06:35 AM
914 Guru Group: Members Posts: 7,159 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I had about 10 flanges laser cut and can't remember where they are.
Lo-Fi Version | Time is now: 27th September 2024 - 04:53 AM |
