Upper Steering Column Bearing Information, 2 Types |
914Sixer |
Nov 30 2020, 08:20 AM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You will have to check to see which type you have.
Metal center bushing use VW 111 953 559A 1972-1973 (maybe some early 1974) Plastic center bushing use VW 111 953 559C 1974-1976 Porsche Part 911 347 771 02 is the same as VW 111 953 559C INA F-580801 is the same as 111 953 559C or Porsche 911 347 771 02 Metal center bushing for VW 111 953 559A is 111 953 535D Added Ebay screenshots of bearing sellers. They are reproductions, German ones maybe NLA at this point. Picture of metal center bushing added. Attached thumbnail(s) |
MM1 |
Nov 30 2020, 02:17 PM
914 obsession continues Group: Members Posts: 619 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
914Sixer |
Nov 30 2020, 02:34 PM
Yes you will be using the "A" bearing.
MM1 |
Nov 30 2020, 02:38 PM
Thank you, Sir!
Coondog |
Nov 30 2020, 03:05 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
So is it the bearing that goes bad or is it the sleeve?
914Sixer |
Nov 30 2020, 03:09 PM
Plastic sleeve breaks apart or crumbles into pieces.
Coondog |
Nov 30 2020, 03:14 PM
Plastic sleeve breaks apart or crumbles into pieces. Thanks, sounds like a good video for Ian to make... (IMG:style_emoticons/default/smile.gif) |
914Sixer |
Nov 30 2020, 03:19 PM
You can back date to early set up with early bearing and steel sleeve. Plug and play swap. That is what I did when I swapped the plastic 75 column to a 73 metal one.
MM1 |
Nov 30 2020, 04:35 PM
Plastic sleeve breaks apart or crumbles into pieces. Thanks, sounds like a good video for Ian to make... (IMG:style_emoticons/default/smile.gif) Just watched Ian's brakes and bearings vid - I think he said he's on to steering column and wiring next . . . Whaddya say, Ian . . .are you going to back date to the metal column in your vid? Hopefully you change the upper and lower . . .ah, the burden of complete instruction, eh? Either way, we appreciate your videos! |
Lo-Fi Version | Time is now: 27th September 2024 - 09:46 AM |
