Gremlin in the Steering Column Stalks.... |
wysri9 |
May 2 2021, 05:03 PM
Member Group: Members Posts: 199 Joined: 23-August 13 From: Aberdeen, Scotland Member No.: 16,291 Region Association: England |
Ok so its all back together and all the electrics work as designed with my new loom. Wonderful you might say. All was well until I installed the steering wheel and then.....turning the wheel causes the headlights to flash....
Any ideas what to look for in the stalk assembly? I am resigned to removing the wheel, but would much prefer not to remove the column assembly unless I absolutely have to. Where should I start...???? Over to the experts for some pointers PLEASE (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
windforfun |
May 2 2021, 05:12 PM
Senior Member Group: Members Posts: 1,956 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Did you overtighten the blinker stalk screws? The stalk assemblies (both) are supposed to "float" in the column with minimal inward clamping force.
wysri9 |
May 3 2021, 09:36 AM
Did you overtighten the blinker stalk screws? The stalk assemblies (both) are supposed to "float" in the column with minimal inward clamping force. You are a star - I was about to remove the steering wheel and the column stalk assemblies to fault find which would also have involved undoing all the secured cables etc...... In the event slackened off the clamp bolt on the whole stalk/ignition and steering lock assembly and bingo- no flashing. Boy I am I a happy chap! Added some Loctite to the clamp bolt and left it nice and slack. Thanks so much for the response. 914 World wins again! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 09:03 AM |
