FS Restored Steel gas caps., 3 available , $35 shipped |
bdstone914 |
Jul 17 2021, 09:29 AM
bdstone914 Group: Members Posts: 4,673 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have 3 original gas caps for 1970-74 cars with steel expansion tanks
They are replated gold zinc and have gaskets made from an aramid fiber material. $35 shipped each Attached thumbnail(s) |
mobymutt |
Jul 17 2021, 08:44 PM
Senior Member Group: Members Posts: 553 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
Bruce, I have a '74, and it always smells badly of gas in the front trunk. Maybe my gas cap isn't sealing? I will take one of these if it will eliminate the smell!
bdstone914 |
Jul 18 2021, 11:24 AM
Bruce, I have a '74, and it always smells badly of gas in the front trunk. Maybe my gas cap isn't sealing? I will take one of these if it will eliminate the smell! I can sell you one but the smell is more likely related to the charcoal canister lines. Look inside of the cap and see if the rubber liner is intact. @mobymutt |
mobymutt |
Jul 18 2021, 05:43 PM
Bruce, I have a '74, and it always smells badly of gas in the front trunk. Maybe my gas cap isn't sealing? I will take one of these if it will eliminate the smell! I can sell you one but the smell is more likely related to the charcoal canister lines. Look inside of the cap and see if the rubber liner is intact. @mobymutt The rubber liner does seem intact, so I will have to look at the lines. Thank you! |
Superhawk996 |
Jul 18 2021, 06:22 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Bruce I’ll take one. I’ll PM you on shipping address.
bdstone914 |
Jul 28 2021, 06:03 PM
Back side
Pappy1975 |
Jul 29 2021, 06:56 PM
Newbie Group: Members Posts: 23 Joined: 19-December 19 From: South Carolina Member No.: 23,745 Region Association: South East States |
Hey Bruce,
I’ll take one. PayPal on the way. David |
DC_neun_vierzehn |
Jul 29 2021, 08:52 PM
Member Group: Members Posts: 438 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
Bruce, I have a '74, and it always smells badly of gas in the front trunk. Maybe my gas cap isn't sealing? I will take one of these if it will eliminate the smell! I can sell you one but the smell is more likely related to the charcoal canister lines. Look inside of the cap and see if the rubber liner is intact. @mobymutt The rubber liner does seem intact, so I will have to look at the lines. Thank you! @mobymutt check the gasket between fuel tank and expansion tank to see if it has gone bad. I recently had an issue with my '73 and that was the issue. And use your nose (where is the smell coming from specifically) and use your fingers (find the moisture) and trace it to the source. https://www.pelicanparts.com/More_Info/N14R...6&DID=33599 |
DC_neun_vierzehn |
Aug 22 2021, 08:49 AM
Pappy1975 |
Aug 22 2021, 10:00 AM
bdstone914 |
Aug 22 2021, 06:29 PM
bdstone914 |
Aug 22 2021, 06:30 PM
"DC_neun_vierzehn" Yes I have one left. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:00 AM |
