Fuel Tank Fiber Washers, Thickness?? |
AvalonFal |
Jul 26 2021, 12:51 PM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
Anyone know the thickness of the Fuel Tank Supply/Return Pipes Fiber Washers?? 1/32"??, 1/16"??
Paul |
Don914 |
Jul 26 2021, 01:32 PM
Newbie Group: Members Posts: 5 Joined: 7-March 16 From: Texas Member No.: 19,734 Region Association: None |
Anyone know the thickness of the Fuel Tank Supply/Return Pipes Fiber Washers?? 1/32"??, 1/16"?? Paul I'm about to put my tank back in. I put the fittings back on with new metal washers and fuel sock (AA). I put on a few inches of hose, clamped them off, put in a quart of gas and waited a few days. They both did weep a bit of gas. I am going to remove them, make sure the end surfaces of the fittings are clean and put it back together and use: "HYLOMAR Gasket Sealant 100g Tube Blue". It is a non setting gasket sealer. I think I saw the idea on this forum. I'll let you know if it works. Ordered it on Amazon, expected Aug 1st! Do you have a source for the fiber washers? Thanks. |
jrmdir |
Jul 26 2021, 02:35 PM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
This: https://www.harborfreight.com/141-piece-was...ment-67552.html
I happened across this when in line to check out. It just happens to have exactly two fiber washers that match the tank fittings. For four bucks I decided all the other pieces were a bonus. I smeared both sides with a light coat of hylomar and have not seen any seepage in more than 6 weeks. One more thing. I did not mark which way the angled sections of the tubes were pointing and it does make a difference how the hoses are routed. I'm sure mine are pointed the wrong way but I made it work. Did not want to loosen and rotate for fear of needing another trip to HF (IMG:style_emoticons/default/smile.gif) EDIT - not sure but it might have been this pack instead: https://www.harborfreight.com/54-piece-wash...ment-67667.html Ron |
AvalonFal |
Jul 26 2021, 04:57 PM
Local Home Depot has various size fiber washers, but they are only 1/32" thick. Paul |
IronHillRestorations |
Jul 27 2021, 06:00 AM
I. I. R. C. Group: Members Posts: 6,761 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I have used aluminum sealing washers
iankarr |
Jul 27 2021, 06:34 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,512 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
One more thing. I did not mark which way the angled sections of the tubes were pointing and it does make a difference how the hoses are routed. I'm sure mine are pointed the wrong way but I made it work. Did not want to loosen and rotate for fear of needing another trip to HF (IMG:style_emoticons/default/smile.gif) On the 3 914s I’ve owned, the pipes have been oriented to about the 2 o’clock position, as if you were viewing from the top down. Or put anothe or way, pointing to the middle of the dash.Others can chime in to confirm… |
rhodyguy |
Jul 28 2021, 09:11 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
See if Rotary914 (member vendor) has any of them. Buy a couple of sets. They keep.
jrmdir |
Jul 28 2021, 09:32 AM
[/quote] On the 3 914s I’ve owned, the pipes have been oriented to about the 2 o’clock position, as if you were viewing from the top down. Or put anothe or way, pointing to the middle of the dash.Others can chime in to confirm… [/quote] Thanks for this. I think mine are completely opposite @ 7 o'clock! I had to loop long hoses to keep from crimping. Will definitely fix when I redo everything with SS lines. |
Lo-Fi Version | Time is now: 27th September 2024 - 10:32 AM |
