Stock Grease Fitting Tie Rod End ?, MOOG ES2096R |
914Sixer |
Aug 25 2021, 02:22 PM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Something I found on line that says it fits 78-89 Porsche 911. Mercedes, BMW. It has all the same measurements as a stock 914 tie rod end. Thinking this should be plug and play for the 914 and give you the grease option. Not sure of what to make of Plastic cover Around $20 at Rockauto.
Attached image(s) |
lierofox |
Aug 25 2021, 02:56 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
Lo-Fi Version | Time is now: 27th September 2024 - 09:22 AM |
