Gathering info on engine rebuild |
dax1969 |
Nov 5 2021, 09:38 AM
Member Group: Members Posts: 372 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None |
Hi guys,
I've read a lot of engine rebuild threads and I am also following Ian on the 2056cc engine build but I am bit overloaded with info. My car is 74 2.0 FI and an engine rebuild will come sooner or later .... I will not do the rebuild myself but before I talk to a shop I want to know what parts (brand !) are needed and what machining needs to be done. Just want to know what you guys would do so I can compare to what the shop wants to do. What I want : * reliability (so not another rebuild 20K miles later) * want to keep the fuel injection * want euro spec * a bit more oomph so 2056 cc (to keep the FI) instead of stock 2.0 * affordable but reliable parts (sorry can't afford a Raby engine or kit) What do I need and which brand ? * new pistons - 96 mm ? * new cylinders ? * new camshaft (which one ?) * complete seal kit ? * SSI heat exchangers ? (have a triad exhaust) * new valves and valveguides ? * keep the original FI or aftermarket modern injection ? What needs to be done to the engine ? * resurfacing heads ? * valves ? * does the MPS needs adjustment (or replacement ?) I see kits, pistons, cylinders all over internet but what are the good reliable and affordable brands ? A complete list with suggested parts and brands would be ideal. Thks in advance cheers Dax |
rfinegan |
Nov 5 2021, 10:40 AM
Senior Member Group: Members Posts: 1,016 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
I pieced my rebuild kit from multi sources to try to safe a few bucks and reuse where I can...you will eat up the savings in shipping cost
https://lnengineering.com/type-4-store.html http://www.europeanmotorworks.com https://www.aircooled.net Heads were back order of 6-8 months.. so plan ahead Here: Is a list of some of the wins and losses on my 2056 build: http://www.914world.com/bbs2/index.php?sho...117&hl=2056 |
ddire333 |
Nov 5 2021, 11:14 AM
Member Group: Members Posts: 91 Joined: 2-November 20 From: ireland Member No.: 24,835 Region Association: Europe |
Just completed similar rebuild to 2056 - like you on a budget in having to import everything plus vat and duty if from outside EU. Assuming your case, heads ,crank etc are ok and stock (big assumption) I would go for:
-change all the bearings -new injectors -aa 96mm piston set -new valves and guides -new or reground cam and new lifters to suit the FI, send mine of to US for regrind about €400 in all -mps rebuild if needed -oil pump - id say optional if your is in good shape -seal kit plus the 2 end seals -clutch kit -change all fuel lines adding it up it cost me about €2500-3000 in parts to fully rebuild all of above, that was with a lot of shopping around. Machine shop cost were on top - just to give you an idea Yes you can do more and buy higher spec parts, but that you be the minimum I would feel and should give a small power bump Heritage parts can ship from Germany, and "stock" aa piston, heads etc but man its slow plan and order parts months ahead I would say. partsworks.de also good on some stuff. |
dax1969 |
Nov 5 2021, 01:57 PM
Thanks for the replies.
Clutch is new and fuel lines are ss tangerine. Also have a 123 distributor. Will further check on the AA pistons. I am close to Germany so think I can find the parts in Europe. Thks again Dax |
Lo-Fi Version | Time is now: 27th September 2024 - 12:57 PM |
