Seats, Drivers seat options |
KMajee |
Nov 7 2021, 10:53 AM
Newbie Group: Members Posts: 6 Joined: 7-November 21 From: california Member No.: 26,059 Region Association: Northern California |
Hello,
took out the original drivers and passenger seat set up and looking to find a good alternative for the drivers seat only. Need something that is low and sets back so that a 6'1" 200lb body can fit. I'm ok to bolt right down to the floor. any suggestions? Thanks! |
mepstein |
Nov 7 2021, 11:30 AM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The stock seat is one of the best for tall people. Most other seats sit taller than the 914 seat. One hack is to cut the seat cushion in half so you sit lower. You can also make up a custom seat cushion with closed cell foam like you use for sleeping pads. Also, remove the back pad and replace with perlon carpeting to make sure your seat can go all the way back.
(IMG:style_emoticons/default/welcome.png) |
JamesJ |
Nov 7 2021, 01:37 PM
Member Group: Members Posts: 228 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
Google is your friend to look for any topic you are interested in researching, e.g., "914world seats"
You may find something here... https://www.classiccarseats.com/ Your waistline is more important than your height and weight when considering seat options. I could not find anything slim enough in the aftermarket and ended up purchasing a period correct Scheel-Mann seat that will bolt right into the 914 seat frame. (IMG:style_emoticons/default/welcome.png) |
KMajee |
Nov 7 2021, 04:02 PM
Hello, took out the original drivers and passenger seat set up and looking to find a good alternative for the drivers seat only. Need something that is low and sets back so that a 6'1" 200lb body can fit. I'm ok to bolt right down to the floor. any suggestions? Thanks! thanks. that's what I'm beginning to think is the best optino. |
Lo-Fi Version | Time is now: 27th September 2024 - 09:20 AM |
