New engine build, prime system |
930cabman |
Feb 9 2022, 06:28 PM
Advanced Member Group: Members Posts: 3,545 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
We are about to fire a new 2056 and have tried to pump oil through the system prior to igniting. I have pulled the spark plugs and hooked up an oil pressure gauge. I can crank the starter for 30 seconds or so, but nothing registering on the gauge? More cranking?
Thanks |
Superhawk996 |
Feb 9 2022, 06:38 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
We are about to fire a new 2056 and have tried to pump oil through the system prior to igniting. I have pulled the spark plugs and hooked up an oil pressure gauge. I can crank the starter for 30 seconds or so, but nothing registering on the gauge? More cranking? Thanks Ideally you primed the oil pump with some light petroleum grease like Vasoline to help that pull suction quickly. If not don't panic. Postitive displacment gear pumps are self priming. Vasoline just helps expedite oil pump prime. Again, ideally a good Moly lube on the rods and cams. Moly isn't going to wear off at slow cranking speeds. No moly? Don't panic, long before there was Moly, mechanics have been using oil to pre-lube without harm. Moly is just nice insurance. More cranking is in order. There is a lot of volume to fill initially before you will develop pressure. 30 seconds at slow cranking with the starter speed isn't much by the time it works its way to the oil pump. Remember oil pump is driven off cam. Cam is driven off crank at 1/2 crank speed. Crank speed and rotation are but a small fraction of starter motor RPM's. @930cabman |
fixer34 |
Feb 9 2022, 06:50 PM
Senior Member Group: Members Posts: 1,160 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
As noted, hopefully there is some assembly lube on all the moving parts. Registering oil pressure just by cranking the starter isn't too likely due to the low speed and volume. You mainly want to make sure the oil galleries are full.
Probably better off to remove the gauge (depending where it sits) and hold a rag over the hole while someone else cranks it. Once you get oil flowing out the hole, you know the pump is primed. Put the gauge or sender back in, then fire it up. Just watch the gauge and make sure it registers in the first 5-10 seconds. |
930cabman |
Feb 9 2022, 07:08 PM
Yes with the assembly lube, all main and rod bearing surfaces, same with cam bearings and plenty on the lifters and cam. I spoke with my local starter/alternator rebuilder earlier and he informed me 30 seconds or 1 minute of starter running time is fine. I have tried a couple times and the last tine I did open the fitting feeding my oil pressure gauge.
Lucky for me, I have the engine/trans on a rolling stand and it is not installed in the chassis. Thanks for the feedback |
iankarr |
Feb 9 2022, 08:02 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,512 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
What @Superhawk996 and @fixer34 said. On my 2056 it took probably 3 x 30 second tries. Assume you're using break in oil, right?
bkrantz |
Feb 9 2022, 08:52 PM
914 Guru Group: Members Posts: 8,065 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Mine took closer to ten 30 second crank spurts.
barefoot |
Feb 10 2022, 07:48 AM
Senior Member Group: Members Posts: 1,318 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
My 2056 build would not produce oil pressure like you're attempting.
I pulled to cover off the pump to discover the pump was DRY !! (I was set-up to do a cam break-in on a garage floor rig so access was easy) I finally discovered that the oil strainer in the sump had collapsed to cover the inlet suction tube. Fixing that cured the problem quickly. I had plenty of break-in lube on all bearings & cam lobes, so everything worked out OK. |
930cabman |
Feb 10 2022, 10:11 AM
What @Superhawk996 and @fixer34 said. On my 2056 it took probably 3 x 30 second tries. Assume you're using break in oil, right? Straight 30 Wt, non detergent I did not pre fill the oil filter, but will pull it today and fill it. |
930cabman |
Feb 10 2022, 10:12 AM
My 2056 build would not produce oil pressure like you're attempting. I pulled to cover off the pump to discover the pump was DRY !! (I was set-up to do a cam break-in on a garage floor rig so access was easy) I finally discovered that the oil strainer in the sump had collapsed to cover the inlet suction tube. Fixing that cured the problem quickly. I had plenty of break-in lube on all bearings & cam lobes, so everything worked out OK. How did the strainer collapse? and how long ago was your build |
bkrantz |
Feb 10 2022, 09:39 PM
What @Superhawk996 and @fixer34 said. On my 2056 it took probably 3 x 30 second tries. Assume you're using break in oil, right? Straight 30 Wt, non detergent I did not pre fill the oil filter, but will pull it today and fill it. Some of the gurus here say not to pre-fill the filter. It is down-stream from the pump and might make it harder to get the pump sucking from the case. For my break in oil, I also used straight 30, and also added a zinc boost. |
Lo-Fi Version | Time is now: 27th September 2024 - 10:06 AM |
