Windshield trim clips |
mb911 |
Aug 11 2022, 06:53 PM
914 Guru Group: Members Posts: 7,162 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
So today my clips broke while driving and my 1000 mile new trim came flying up. What is the story with these clips. I wish they were made of steel. My 1st 914 had steel ones and they were great. Is one source better than another? They are waaay to brittle.
StarBear |
Aug 11 2022, 08:40 PM
Advanced Member Group: Members Posts: 2,054 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Wow. That really sucks. (IMG:style_emoticons/default/mad.gif)
bkrantz |
Aug 11 2022, 08:41 PM
914 Guru Group: Members Posts: 8,065 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I heard some things about non-OEM clips made of plastic that is more brittle, so I sourced Porsche factory clips for mine.
mepstein |
Aug 11 2022, 09:06 PM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The first version of 914rubber clips were too brittle. I think they either fixed them or buy from another source.
I gave a set of clips that I purchased on Pelican to a semi local guy in the middle of a window install. His 914rubber clips were breaking upon installation. |
mb911 |
Aug 12 2022, 05:14 AM
It's amazing that it happened. Now I am nervous to even drive it. Makes me really mad.
dr914@autoatlanta.com |
Aug 12 2022, 09:04 AM
914 Guru Group: Members Posts: 8,055 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
happened to me years ago when I did not replace the clips when installing new windshield chrome, blew off and a truck ran over it.
mb911 |
Aug 12 2022, 09:35 AM
Root_Werks |
Aug 12 2022, 10:05 AM
Village Idiot Group: Members Posts: 8,425 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I bought new trim from SMC, actual Porsche trim which came with clips. I only replaced the ones I needed to. You can totally feel the difference. The clips that were still good and on the car would flex and the new ones were very hard to flex or bend even a little.
I also had a scare after a drive. Came back to find part of the upper drivers piece had come unclipped. Wiggled it back in until I could feel each clip "snap". Fingers crossed I don't see trim flying off someday. (IMG:style_emoticons/default/sad.gif) |
Mikey914 |
Aug 12 2022, 01:03 PM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The clips to need to snap the trim in place. If not they can be picked up and you can loose some trim.
mb911 |
Aug 12 2022, 01:42 PM
IronHillRestorations |
Aug 13 2022, 06:09 AM
I. I. R. C. Group: Members Posts: 6,761 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Only use genuine Porsche windshield clips
mepstein |
Aug 13 2022, 07:25 AM
Only use genuine Porsche windshield clips (IMG:style_emoticons/default/agree.gif) Pulled these out of my 70 parts car. One owner. Original windshield (cracked unfortunately) the clips are still flexible and very strong. Attached image(s) |
mb911 |
Aug 13 2022, 09:02 AM
PanelBilly |
Aug 13 2022, 09:43 AM
914 Guru Group: Members Posts: 5,840 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
When I was in NC I visited Black Forest Racing and had a long visit with the founder. Can’t remember his name for the life of me. Anyways I asked him about the clips. He said that his trick was to use a drop of glue on each clip. Then if the snap failed there was still glue. I tried it and I my trim still doesn’t stay tight to the car. Hate to pull it all apart again but it’s on my winter list.
mb911 |
Aug 14 2022, 07:43 AM
When I was in NC I visited Black Forest Racing and had a long visit with the founder. Can’t remember his name for the life of me. Anyways I asked him about the clips. He said that his trick was to use a drop of glue on each clip. Then if the snap failed there was still glue. I tried it and I my trim still doesn’t stay tight to the car. Hate to pull it all apart again but it’s on my winter list. I need to put that on my spring list. My 928 is not done yet. I am doing the transmission this fall so it will push back 914 work unfortunately. |
iankarr |
Aug 14 2022, 10:44 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,512 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I wonder what would cause the clips to break after 1000 miles of driving. They'll usually break on installation. Important to enusre the trim snaps in on every clip, which is easy to test. Curiious...which piece of the trim lifted up first? Sometimes the rubber spacer block on the bottom can prevent the trim from fully clicking in. If your bottom piece came out first, I'd suspect that.
Lo-Fi Version | Time is now: 27th September 2024 - 11:52 AM |
