Advice needed on cowl-fender repair areas and rust in welds |
doug_b_928 |
May 18 2023, 10:48 AM
Senior Member Group: Members Posts: 703 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
After no progress in 2022 due to other time commitments I'm ready to get back to my restoration. Most of the rust repair on the middle and rear of the tub is done, but I still have the front end to do. I'm at a crossroads with respect to the cowl-quarter channels.
It's very difficult to see and even more difficult to get good pics but the right side channel has some spots where it has rusted through. Here are some pics: But the underside looks great to me. Here's pic of the underside which I cleaned up, rust treated, and epoxy primed several years ago. The left side fender-cowl channel is in better shape when looking down into it. Here is a pic: I removed most of the seam sealer from the underside but still need to clean it up. As shown in the pic below, there is a spot of rust but it does not look like it has rusted through, so I expect this side to clean up as nicely as the right side. So, question #1 is how to deal with these areas. There aren't many threads that deal with their repair but having studied the ones I could find I think I have a good sense of how the two pieces are welded together. It looks like it might be difficult to remove the spot welds in the door area. I believe I can do it but I'm wondering if wire wheeling, treating with metal prep, epoxy priming and then seam sealing might be what's best in this area. Obviously best is always to cut it out and get rid of any sign weakened metal but then getting the panel to look as good after the repair might be a challenge and since this location is kind of buried maybe it's better to leave the nice lines on top and treat it. On the other hand, if it's going to be an issue in the future then I'd rather cut it out and repair now. So this is the conundrum. What say the brain trust? The top side of the cowl is in nice shape and the channel for the windshield has some pitting but not perforation. I still need to take a wire wheel to the windshield channel. Here are some pics: Unrelatedly, one benefit of taking forever to do the rust repair is one gets a chance to see where rust wants to rear its ugly head again. There are 4 spots where I can see some rust on the epoxy primer. Two of them are on the left suspension console where I did the 'weld little rust areas with the mig' techniqe. Here are pics of those: And the other two are seams where new metal was welded to old. One is on the rear trunk floor crossmember and the other is below the right rear tail light. So, Is this a matter of some rust mixed in with the weld or is that there was still rust behind the area that needs to be dealt with? Attached image(s) |
doug_b_928 |
May 18 2023, 11:00 AM
P.S. Sorry about the double of one of the pics. The other one is the frunk channel. There are areas of channel that I need to replace but then there are some other spots like the one shown where it is pitted but not rusted through. Also wondering if this should be removed and replaced or treated.
mgphoto |
May 18 2023, 02:09 PM
"If there is a mistake it will find me" Group: Members Posts: 1,363 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Looking at a few of the photos there is a lack of correct surface prep and the rust pushed through the epoxy primer.
A lot of extra work. The channel can be treated for the rust and then sealed, I had lots of rust through, I used a cutting disk to remove the rust and mig welded the cuts. |
r_towle |
May 18 2023, 02:14 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
it may help to get one of the small hand held sand blasters and use some glass bead, or black beauty....underneath to remove all the non metal sealer and filler under there, then into the crack.
Also on the areas that have started to rust again...blast them clean and prep the metal properly...then paint again. rich |
mgphoto |
May 18 2023, 04:59 PM
I use this for rust removal and surface prep, creates a great key.
https://wurthtool.com/products/dbs-3600-bru...LwaAorqEALw_wcB |
Montreal914 |
May 19 2023, 10:13 AM
Senior Member Group: Members Posts: 1,675 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
This is my repair so far of the cowl area.
http://www.914world.com/bbs2/index.php?sho...=349463&hl= I seriously think this trench where the rubber trim goes into should not be plugged by seam sealer but allowed to drain in the empty void between the door and the fender. (IMG:style_emoticons/default/idea.gif) |
doug_b_928 |
May 20 2023, 07:51 AM
Thanks for the replies. For metal prep I'm degreasing then using POR Metal Prep, letting it dry over night, and then epoxy primer. It appears to have worked very well except in the spots I've pictured. I'll remove the epoxy and get a better look at what happened; cut and redo if necessary.
The big question is what to do about the fender-cowl area. Montreal914's repair looks thorough and nice. In my case I don't see a need to replace the cowl and my quarter isn't rusted through like his was. So it makes me wonder what is the best thing to do here... There was no rust bubbling on top or bottom in this area, it seems to be just in the channel so I'm wondering if treating and epoxying will do the trick and it might never be an issue... Montreal914 has linked his thread which is excellent. The only other one which is also excellent at showing how the panels connect is here: http://www.914world.com/bbs2/index.php?showtopic=110572. It has links to some others as well. T |
mepstein |
May 20 2023, 08:02 AM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Anyplace that has multiple layers of metal probably has some rust and corrosion. It just depends how far down the rabbit hole you want to go.
Montreal914 |
May 20 2023, 09:22 AM
Agreed, every time I separate two healthy metal piece, rust is present in the interstice. (IMG:style_emoticons/default/headbang.gif)
I too don't want to fix the driver's side cowl as there are no signs of heavy corrosion like my passenger side had. That being said, the trench for the rubber trim will need some corrosion stopper. I have places a paper towel impregnated with ospho in there but how deep did it really go in between the metal joint is unknown. Having gone through the hell of fixing the passenger side, I don't plan on dismantling the driver side. Definitely looking forward hearing others commenting your your very relevant question. (IMG:style_emoticons/default/popcorn[1].gif) |
doug_b_928 |
May 20 2023, 10:19 AM
Well, I'm about as far down the rabbit hole as Monreal914 et al (e.g., Brent Brock). But Montreal914's experience and decision to leave the driver's side alone says a lot. I agree, every seam on these cars with healthy metal when separated has some rust in between so a truly rust free car would need to have every seam separated and treated. But the rust in those areas is really a surface rust that I doubt will ever cause problems (if it hasn't already in the past 50 years). This channel where the rubber goes appears to be a different story as some people have bubbling in the area. I don't want to paint the car and have to re-paint it because rust rears its ugly head there, but there appears to have never been rust on the visible parts of the panels anyway so that's where the blast, wire wheel, treat, and epoxy the crevace approach comes in and might be the best course of action here.
Like Montreal 914, I too look forward to hearing what others who've done this repair have to say. Given that there are only a few threads where people have documented this repair it seems that this area may rarely get surgery, which may also be telling... |
rhodyguy |
May 20 2023, 10:25 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Mar-Hyde one step rust converter.
Geezer914 |
May 20 2023, 11:06 AM
Geezer914 Group: Members Posts: 1,656 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Eastwood Rust Converter.
doug_b_928 |
May 20 2023, 07:47 PM
Two votes for rust converter duly noted.
zoomCat |
May 21 2023, 08:53 AM
Member Group: Members Posts: 180 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None |
Two votes for rust converter duly noted. It appears that not all rust converters are equally effective. This guy did some testing: https://www.youtube.com/watch?v=tu1n1POMg98 |
doug_b_928 |
May 21 2023, 09:28 AM
Watched that one and some others earlier this morning. Seems that the best ones are phosphoric acid based. I’ve been using POR metal prep (zinc phosphoric acid) and it has worked well except for the spots in my first post.
Literati914 |
Senior Member Group: Members Posts: 1,664 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I’ve replaced the “pointy” sections of the fenders/cowls on both sides of my current project, probably 10-12” back on each side. they were both rusted thru. I think part of the problem is that enough paint doesn’t get down into that channel when paint was applied at the factory. So what I plan to do is flood and clean the trench(s) with phosphoric acid and water, then get por-15 paint down into the trench with the use of Q-tips, followed by a top coat of regular paint as normal when I paint with the gun.
r_towle |
May 21 2023, 12:58 PM
Thoughts on using a rust converter then welding the seam closed forever?
mgphoto |
May 21 2023, 05:16 PM
Thoughts on using a rust converter then welding the seam closed forever? Rust converter will burn when exposed to welding temperatures. That stuff is a bandaid, cut out the rust, weld in new, cover with primer, 30 year repair, rust converter, how long? Who knows, I coated the battery box with Navel Jelly 30 years ago and I just replaced it. |
930cabman |
May 23 2023, 05:05 AM
Advanced Member Group: Members Posts: 3,544 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Thoughts on using a rust converter then welding the seam closed forever? Rust converter will burn when exposed to welding temperatures. That stuff is a bandaid, cut out the rust, weld in new, cover with primer, 30 year repair, rust converter, how long? Who knows, I coated the battery box with Navel Jelly 30 years ago and I just replaced it. Our sporting machines have been around for 1/2 century with minimal care. In another 1/2 century will it matter. W will probably be on to the Jetson age. |
mepstein |
May 23 2023, 05:17 AM
Rust repair becomes a challenge when paint is part of the equation. Nobody wants to spend $10-20K on a paint job, just to have bubbles appear in the paint, months later. Getting rid of the rust and properly preparing the metal is the only way to mitigate the issue.
Lo-Fi Version | Time is now: 26th September 2024 - 09:53 PM |
