help with 5th gear, I can get it in but .. |
jimkelly |
Aug 28 2005, 03:27 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
it pops out.
I have a 1972 914 with 1976 2.0 and tailshifter tranny. I can get into 1st and reverse with no problem. I can upshift to 2nd ok. I can upshift to 3rd and 4th excellently. I can shift into 5th fine but the shifter pops out immediately. What is the likely culprit ?? Thanks, Jim |
john rogers |
Aug 28 2005, 04:21 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
You might want to check the engine mounts in the front and tranny mounts in the rear to see if they have ripped the rubber apart? If they are good, then check the set screws (both) to see if they are tight, then the bushings and finally the pinch bolt that clamps the front shift rod to the shifter as it can loosen. Good luck.
jimkelly |
Aug 28 2005, 04:48 PM
Would you say the pop out problem is not the tranny itself but some or one of the other things you mentioned? All my shift linkage bushings have be replaced - my tranny bushings are torn but looked to be stiff enough as to not move around - maybe they are though ??
Thanks |
Lo-Fi Version | Time is now: 27th September 2024 - 01:18 PM |
