Wheel offset with GT flares?, Rondell #58 wheels |
ORANGE2 |
Nov 29 2005, 11:51 PM
Newbie Group: Members Posts: 25 Joined: 12-February 03 From: Roanoke, TX Member No.: 305 Region Association: Northstar Region |
I would like to try and put some Rondell Model # 58's on my 914. I currently have 914/6 fuchs on my car now with 5 lug adaptors(not conversion). I also put a set of steel GT flares on the car. I need to know what the offset should be, what the hub bore is, and the lug pattern 5 x 120????. Any help would be appreciated.
Thank you. Aaron 74 2.0 |
Mueller |
Nov 30 2005, 01:19 AM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Porsche is 5x130mm
do they make those wheels in Porsche fitments or only BMW? |
Mueller |
Nov 30 2005, 01:32 AM
Here is Joe O'Briens car with 17x9s (255/40/17) on the back, 53.3mm offset with a 42mm spacer (I'm sure you can do the math (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) )
for the front, many people run a 7" wide rim with a 23mm offset and a 1" spacer to move the wheels out closer to the fender (IMG:http://www.914world.com/bbs2/uploads/post-2-1102614957.jpg)with |
nomore9one4 |
Nov 30 2005, 07:52 AM
Member of the Eastcoast Thread Killers Club Group: Members Posts: 2,666 Joined: 26-December 02 From: Pittsburgh,Pa.15237 Member No.: 14 Region Association: None |
That car is going to be sweet. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Aaron Cox |
Nov 30 2005, 09:35 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
why a 7" with a spacer? just run an 8". 7's fit under stock fronts... and ive seen an 8" understock..... |
ORANGE2 |
Nov 30 2005, 10:25 AM
I've seen them on Porsches in some of there ads
d914 |
Nov 30 2005, 11:24 AM
Advanced Member Group: Members Posts: 2,333 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
7 or 8's I have run at least a 15mm spacer upfront, push them out a bit and or to keep the tire off the inside at lock, especially with slicks.
Ronals come in 5x130 and proper offsets, had a set, 16x9 16x8's. et 15 on the back is good with the larger rims and flares |
Mueller |
Nov 30 2005, 01:01 PM
I dunno, you got to ask the people running them (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) with the 911 16x8, you'll still want to run a spacer and the 951 16x8 which would fit better without a spacer is expensive.... so, it I'm guessing cost and or that they are running 8's in the rear and want smaller rims up front... |
Mueller |
Nov 30 2005, 01:02 PM
wrong brand, he is looking at Rondells....not Ronals (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
d914 |
Nov 30 2005, 04:03 PM
opps, back to reading class (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Lo-Fi Version | Time is now: 27th September 2024 - 12:40 PM |
