Brakes, or the Lack of |
Nick |
Dec 3 2005, 05:57 PM
Member Group: Members Posts: 144 Joined: 25-June 04 From: Washington DC Member No.: 2,250 |
I spent today installing new rear wheel bearings and that went OK I think. I left the swing arm on the car and just unbolted the rear brake calipers, but left all the lines connected. I backed out of the garage and the brake pedal went straight to the floor. Pumping didn't seem to help. I can see no leaks and the brake fluid is full. I lift the car off the ground again and had a helper step on the brakes. all the wheels locked to the point I couldn't turn them by hand. I guess the question is what should I look at next?
Nick |
ClayPerrine |
Dec 3 2005, 06:18 PM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Two things...
1. check the venting clearance on the rear pads. 2. Bleed the brakes. |
Nick |
Dec 3 2005, 06:45 PM
I should have added brakes are off and 80's 911 so I think there are no venting clearance issues. As for Bleeding I'll give that a try, but the brakes felt great on the last trip. I'm guess it is a Master Cylinder failure, but would like to do some trouble shooting before I order a new one.
Nick |
Eric_Shea |
Dec 3 2005, 11:19 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
If you suspect a M/C you should check the floor around your pedal assembly. Any failure will probably show up there.
Bleyseng |
Dec 4 2005, 09:17 AM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Dave_Darling |
Dec 4 2005, 04:09 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
To fit the calipers back over the rotors, you did have to push the brake pads back in a little ways, right?
That first press of the pedal pushed the pads against the rotor. It's perfectly normal, and is the reason that you always pump the pedal a time or two after you do any brake work. --DD |
Nick |
Dec 5 2005, 10:41 PM
Pumped the brakes like crazy and it doesn't help at all.
Nick |
Lo-Fi Version | Time is now: 27th September 2024 - 12:03 PM |
