When do you guys shift?!, Give it to me! |
cbenitah |
Feb 8 2006, 12:30 AM
Protected by the Swedish Maffia Group: Members Posts: 848 Joined: 16-August 05 From: San Diego, CA Member No.: 4,597 |
Just a question, tried for a search but nothing..
For a -74 1.8l when is time to shift?! it sounds like my engine does not like high RPM's.. or is it just me?! Right now the highest I have gone is 3800-4000.. usually around 3000 is when I shift.. any advice would be nice... also a short shift story, what speed/gear/RPM are you at.. for you guys with the same motor.. thanks! This post has been edited by cbenitah: Feb 8 2006, 06:57 PM |
SirAndy |
Feb 8 2006, 12:33 AM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
that seems low ... max. HP is at 4800 for the EC and 5000 for the AN ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
cbenitah |
Feb 8 2006, 12:34 AM
yea i know... I saw a post that said the car is alot better at 4500 ish.. hmm.. maybe i should go out and try it (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
brer |
Feb 8 2006, 12:59 AM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
Andyrew |
Feb 8 2006, 02:37 AM
miles told me a long time ago that I should TRY to keep the car above 3k rpm's. The fan on the engine needs to stay that high to keep the car cool...
I generally kept it between 2500 and 3300rpm's. that was a while ago.. Oh and I shifted at like 4800 cus my engine didnt like revving (cept once, right after a valve adjustment... twas nice..) |
sean_v8_914 |
Feb 8 2006, 03:48 AM
I shift when the valves start to float or after teh apex, whichever comes first (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
redshift |
Feb 8 2006, 03:55 AM
When I hear the valves float, I put my hand on the shifter...
When I hear a funny knocking sound, I count to ten... if I don't hear the 'tiny metal hammer' sound by the time I count to 15, I go ahead and shift anyhow. Where is peak horses on a 1.8? Shift 500 above that, and cruise in any gear at around 2/3rd of that range.. you know, give-or-take a teeny. If you find yourself under 2700, start looking for a downshift, at least, or lug it.. and lose it. It adds up. M |
bd1308 |
Feb 8 2006, 06:17 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
I shift when metal parts spit out of the exhaust.
is that bad? actually I shift at 5000 usually, unless i'm pissed off, then i'll double clutch it at 6000 (it doesnt like that much).... b |
Joe Ricard |
Feb 8 2006, 07:12 AM
Hmm, Street driving 3000 to 3200 light acceleration not racing nobody.
Autocross 5800 with barely a lift off the gas. I will rev it past that if I can save a shift and make it to the next feature. about 6800. But I'm balanced with dual valve springs yada yada. |
Demick |
Feb 8 2006, 09:34 AM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
I think you came to the wrong place for that question.... (IMG:http://www.914world.com/bbs2/html/emoticons/stromberg.gif) |
ClayPerrine |
Feb 8 2006, 09:38 AM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
When the front end passes the back end on a winding mountain road with a dropoff on one side, a sheer cliff on the other, and an 18-wheeler coming the other direction. But it is very hard to clean (IMG:http://www.914world.com/bbs2/html/emoticons/stromberg.gif) out of the basketweave. |
Dave_Darling |
Feb 8 2006, 09:52 AM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Stock motor, normal driving--I try to keep the revs around 3000-3500.
AutoXing or trying to wring all the performance out of it I can--I shift between 5000 and 5600. Usually higher in the lower gears (except first; I'm never trying to get all the performance out of first gear!) and lower in the taller gears. For instance, I shift from 4th to 5th at about 5200 RPM, while I shift from 2nd to 3rd at the stock redline of 5600 (or, sometimes, when I hit the rev limiter). --DD |
ClayPerrine |
Feb 8 2006, 10:03 AM
Funny... I thought you shifted after one of the rockers breaks........ (IMG:http://www.914world.com/bbs2/html/emoticons/owned.gif) |
dmenche914 |
Feb 8 2006, 10:53 AM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
agree with DD on this, normal driving you should shift around 3000-3500 or so. I think of it this way, at freeway speed I am running about 3500 rpm (varies with tire type) So thats about the max rpm I need to travel. To get up to freeway speed, any engine rpms higher than what I ultimatly need on the freeway i consider wasteful of fuel, and engine wear.
technically I suppose you coulod shift at or near the redline (5800 or so) however that will waste gas,a dn result in more engine wear/heat. It could kill a sick engine pretty fast also. Now if you are racing or such, then gas use, and engine life may not be as big an issue, so you can accelerate faster with higher engine speeds before shifting, there is an optimal set of shift points for racing, but that would depend on your enigne torque and final gear ratio. The optimal shift point may not be the redline either, but goin g to redline is probably most wasteful of gas, and hardest on the engine, as is the opposite extreme of low low rpm lugging (1200 rpm or so0 again dependent on the engines torque curve. The factory torque curves are printed in the owners manuals (the glove box sized book that came with the new car) You can look at it and find the optimal stock set up shift points based on torque (road slope, cargo wieght and such will change these numbers some) Stay within the 3000-3500 limit and you can't go wrong, it is high enough to not lug the motor, and low enough not to over stress it. Nice thing about these old aircools is you can hear them so well, you can shift without the tach by all the racket. Get in a smooth sound deadened new luxury car and you can barely hear if the nmotor is running, much less how fast it is spinning. If you aircooled starts getting more loud, it's time to shift! 4000 rpm is loud enough for me, i can hear it, it sounds much more buzzy than 3000 rpm, good audio feedback on the 914! |
Eric_Shea |
Feb 8 2006, 01:53 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Usually after a good cup of coffee in the morning... (IMG:http://www.914world.com/bbs2/html/emoticons/stromberg.gif)
dmenche914 |
Feb 8 2006, 03:51 PM
From a physics point of view, it is a waste of Entropy and that is BAD, if the engine RPM exceeds that which you need as your max rpm at cruising speed in top gear? I think entropy would be consumed just from the fact pistons and cranks and such are moving at a higher peak velocity than otherwise would be needed., plus the acceleration deference in the cars enitre mass. ie I can get onto the freeway and cruise at 70 mph and never exceed 3500 rpm from start to fifth gear. that uses less entropy than if I get up to freeway speed faster by running up the rpms before shifts.
More energy is spent, entropy destroyed, and entropy we all know is a limited resource, when its gone its gone. At least 914's by their virture of a small relitive mass to the other cars, provides a conservation of entropy, a side benifit of limited crash protection. Less entropy destruction will lead to longer engine life. And this can be shown by a cylinder head temp (CHT) gage. with one you will notice considerable instantanious temp increases when you put the peddle to the metal and race off fast revving it up. You can keep the head temp tens of degrees cooler by shifting at moderate 3000ish rpms. There is plenty of stuff on head temps and head life out there, so I say not more on that except cooler is better (if warmed up) for engine life. An oil temp gage would not detect the sudden quick head temp changes, so don't bother to use one to prove this, you'll melt your heads first trying to. its twisted, but true. save entropy, and save your engine. folks that want to race or go fast don't worry about entropy as much. higher quality parts, build, and maintenance of an engine can help combat the ill effects of excess entropy destruction Its all physics. |
r_towle |
Feb 8 2006, 04:01 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
5-5400
Or when I feel the valves float. Rich |
Joe Ricard |
Feb 8 2006, 04:02 PM
If I was worried about whatever that is ENTROPY ? I would still have my 89 Dodge Aries K car.
I have a Sports car which means I must go fast, As fast as possible. Plus I have spares, engines, transaxles brakes and the where with all to repalce them when I want. So wring it's neck and go like hell. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
dmenche914 |
Feb 8 2006, 04:10 PM
That's the spirit "End entropy drive fast", I like it! just remember good parts, and maintenance for the most thrills per engine
jimtab |
Feb 8 2006, 07:45 PM
Advanced Member Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
Everyday stuff 3500-4000. when I mean it...when the rev limiter starts to "rattle"........ (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Lo-Fi Version | Time is now: 27th September 2024 - 02:17 PM |
