counter weights, are sticking |
toon1 |
Mar 16 2006, 08:41 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
the couner weights are sticking in the dist.. How do I get the shaft out to get to the weights?
toon1 |
Mar 16 2006, 10:36 PM
McMark |
Mar 16 2006, 10:43 PM
To remove the distributor from the engine case, just remove the nut between the distributor and the oil fill. To access the weights, remove the screws on the outside and the advance plate lifts up to reveal the weights.
toon1 |
Mar 16 2006, 10:48 PM
I have the dist. to that point, can I remove the shaft?
McMark |
Mar 16 2006, 10:55 PM
PITA!!! Knock the roll pin out of the drive on the bottom and then the shaft will come out.
toon1 |
Mar 16 2006, 11:05 PM
which part is the PITA? the roll pin?
Is it worth it to remove the shaft or should I leave it in? |
Cap'n Krusty |
Mar 17 2006, 12:10 AM
The weights aren't sticking, the outer shaft isn't turning on the inner one. Failure to oil the felt on a regular basis is the cause. It's hard to explain how to do it, but you have to support the cam portion while knocking the inner portion down with a punch. Once the snap ring is off and the springs disconnected, the outer part comes off the inner one. Clean the rust out, lube it, reassemble it, and reinstall the snap ring. Harder than it sounds, and don't mix up the weight and spring location and orientation. You don't have to remove the roll pin to do this job. The Cap'n
toon1 |
Mar 17 2006, 08:50 AM
Great info, the felt you are refeering to, is that the felt you can see ontop of the dist. where the rotor goes? |
dstar |
Mar 17 2006, 08:53 AM
Member Group: Members Posts: 196 Joined: 19-January 06 From: Ramstein, Germany Member No.: 5,438 Region Association: Germany |
YEP!
When I change the oil, I use the cap from the oil bottle and put a drop in there. Don |
Cap'n Krusty |
Mar 17 2006, 09:14 AM
I use the dipstick for the same purpose. Just enough oil, on a handy applicator! The Cap'n |
toon1 |
Mar 17 2006, 11:54 AM
Is it worth it to just try a little oil first be fore a full swap?
toon1 |
Mar 17 2006, 12:42 PM
I put a couple drops of oil on the felt.
I also took a look at the other dizzy I have apart and seen the clip you are talking about. OMG, how in the world does that get removed? I think I will clean up the extra and do a swap. Is this worth a pictorial for the classics? |
dstar |
Mar 17 2006, 01:13 PM
I don't know about a pictoral, but you cna just spray the hell out of
it with WD-40, run it for 5-10 miles and oil the felt again. Unless it is totally rusted/gunked up, that should loosen things up a bit! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Don |
McMark |
Mar 17 2006, 04:38 PM
PB Blaster. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
bd1308 |
Mar 17 2006, 04:46 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
PB is great on anything...I kept everything together, and rebuilt my dizzy in the hallway of my dorm.
I had one flathead screwdriver and a can of carb cleaner and some paper towels. After thirty minutes, the dizzy FULLY turned and was very smooth. Ya just gotta get the parts to move and move, oil some and spray with carb cleaner to clean out...repeat. After about an additional three or so months, I sold the dizzy to Gint who is assumably still using the dizzy. b |
Lo-Fi Version | Time is now: 27th September 2024 - 12:34 PM |
