Best sealant for Guide bush on tranny? |
tod914 |
Jun 10 2006, 07:27 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Seems once a year I'm fixing a small leak around the guide bush where it goes into the tranny. Each time I replaced the o-ring and used hylomar. After time,
it leaks again. Any reckomendations on a better sealant??? The angle drive is new too, so thats ok. Thanks |
Dr Evil |
Jun 10 2006, 08:03 AM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
How is the sealing surface inside the bore? You may find that some 4-500 grit sand paper used in a circular motion should clean up any light hang ups. If the surface is thrashed beyond that then you may want to try one of the "Threebond" sealants like 1104 of 1201. Wihta new O-ring it should not leak. It is not a pressure fitting so I would suspect something else is the cause.
tod914 |
Jun 10 2006, 08:23 AM
The guide bush is a replacement which seemed in excellent shape. I used the new one when I replaced the angle drive last summer. The o ring seems shrink over time. Next time I fix it, I'll try your suggestion and go with the original guide bush. There seems to be alittle spacing around the guide bush when you insert it the tranny, but its secure when the bolt is tightened. Both matting surfaces where smooth. I throughly cleaned them with brake cleaner prior to reassembly.
Thanks for the tip. |
Cap'n Krusty |
Jun 10 2006, 08:46 AM
My money's on a worn bore in the nose cover. If that's the case (and it's REALLY common) there's little you can do. Since there's RARELY any reason to remove the speedo drive insert, a more permanent repair might be your best move. In the past I've found JB Weld performs well in this specific repair. The Cap'n
tod914 |
Jun 10 2006, 10:24 AM
My old angle drive needed replacement.. was very loose at the pivot. Once you JB weld it, any chance of breaking it free if you need to?
Dr Evil |
Jun 10 2006, 10:59 PM
Tod,
Just see if anyone has a spare cone for you. Tail or side shift? I bet you could get one for low $$. |
tod914 |
Jun 11 2006, 07:51 AM
Thanks Mike your inclined to think thats the issue? Is the bushing suppose to be snug in that sleeve prior to tighening? It seems to seat fine, but there is play around the edges if that makes any sence until I tighten it. Mine is 75. Side shifter.
Lo-Fi Version | Time is now: 27th September 2024 - 12:55 PM |
