Removing wiring harness from tunnel?, which way does it come out easiest? |
Joe.D |
Oct 18 2003, 05:44 PM
MCMLXXIII MCCM Group: Members Posts: 132 Joined: 16-June 03 From: Southern Maine Member No.: 830 |
I need to remove everything from the tunnel in my '74 in order to sand blast away the rust in there.
Is it possible to remove the wiring harness in either direction? If so, which is easier? Pulling then engine end INTO to cabin, or pulling the dashboard end into the engine compartment? Because its a '74, I have those big seat belt interlock relay mounts to deal with as part of the extraction . Joe (IMG:style_emoticons/default/unsure.gif) |
Slowpoke |
Oct 18 2003, 06:34 PM
Member Group: Members Posts: 116 Joined: 1-June 03 From: Tucson, AZ Member No.: 768 |
The way I removed mine was to pull it into the passenger compartment from the front and back. Gets a little trying but I got it out in as good of condition as it was prior.
Peter 74 2.0 (IMG:style_emoticons/default/smile.gif) |
Mueller |
Oct 18 2003, 08:01 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
I just pulled my harness out last week, engine compartment TO the passanger/driver compartment is how I did mine.
SirAndy |
Oct 18 2003, 10:29 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
all the above.
- rear (trunk + engine etc) goes through the rear firewall inside. - front (trunk etc.) goes through front firewall inside. - then, the back part needs to be routed through the tunnel and out in the front. - that's it. assembly is the reverse. - i've done that 4 times now (IMG:style_emoticons/default/wink.gif) Andy |
mr914 |
Oct 21 2003, 09:52 AM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
What do you use to Remove/reinstall the grommets?
SirAndy |
Oct 21 2003, 11:44 AM
QUOTE(mr914 @ Oct 21 2003, 08:52 AM) What do you use to Remove/reinstall the grommets? what grommets? if you're talking about the big rubber protector on the engine side of the firewall, the whole thing goes through the firewall hole. you don't remove it from the harness. you might have to take the plastic cover off some of the multi-pin connectors to get them through. just make sure you remember which wire was in which pin-hole. (IMG:style_emoticons/default/smile.gif) Andy |
Lo-Fi Version | Time is now: 27th September 2024 - 12:13 PM |
