Wheel Alignment |
Wheel Alignment |
Howard |
Sep 15 2006, 05:06 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Dave_Darling |
Sep 15 2006, 06:34 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Understeer is what I think of them. You've got just under two full degrees more negative camber in the rear than the front!! Unless you've got some mighty stiff springs in the back, I'd think this car would push like a Honda Civic!!
If it were my car, with my suspension, I'd set the front at a half-degree closer to zero camber than the rear is. If possible--it may not be, depending on the exact chassis, ride height, etc. --DD |
Aaron Cox |
Sep 15 2006, 06:42 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
more camber in front...
i have mine.... im running -2 in rear.. and almost -2 in front (IMG:style_emoticons/default/smile.gif) |
Joe Ricard |
Sep 15 2006, 06:54 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Tune for the tires. New Azenis are pretty grippy. 1.0 negative camber front 1.5 rear The one angle I don't like is rear toe of the passenger side. it is toe'd out. Pretty easy to fix right in your driveway. Just put a ratchet strap around the outside end of the rear suspension mount loosen the three bolts and carefully crank the end fwd tighten and your done.
Dave_Darling |
Sep 15 2006, 08:06 PM
Howard |
Sep 15 2006, 08:07 PM
The alignment was done with the street 195/65's on American Racing VW offset wheels. They stick out further than the 205's on Fuchs and exaggerate the camber.
180# rears with Konis, Bilsteins up front, swaybars F/R. With the previous alignment and Azenis, I didn't have the HP or courage to break the fronts loose, so back would come out pretty easily, the way I like it. But car tracks/rides better and steers easier with the new setup, some of it due to the higher profile tires of course. This is the setup to drive the almost 2k miles for RRC. Camber aside, what about big changes to toe, caster and thrust angle? When I get back will probably put the stickies back on and re align. Joe.. he couldn't do much more on right side due to tire rub issues that won't be there with the Fuchs. What is ideal rear toe? And don't be a smart ass AAron... |
Dave_Darling |
Sep 15 2006, 08:37 PM
So the right-rear really is still toed out? That's not so good. (IMG:style_emoticons/default/sad.gif)
Ideal toe angle depends on a lot of things. For the street, you want "a little toe in" all the way around. It helps keep the car nice and stable. A little toe out in the front can help the initial turn-in, but at the cost of making the car feel quite "twitchy". Good for an autoXer, not so good for a daily driver. Or even for a track car, for that matter! I'd be a little worried about the difference in caster in the front. It's not a big deal, but it's better for it to be even. And it shouldn't have been difficult to change. Not sure what the "thrust angle" is measuring, but I would assume any issues there would go away when you got toe-in on both rear wheels. --DD |
Aaron Cox |
Sep 15 2006, 08:41 PM
1/16 toe in is good
John |
Sep 15 2006, 08:47 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I would prefer to get the thrust angle to zero. (This is the angle that the rear wheels are pointed toward compared with the vehicle centerline) When both rear toe angles are equal, the thrust angle is zero. This would want to drive the car in a straight line and not drive down the road crooked or dog legged.
I think just a bit more toe in in the front. Less negative rear camber, more negative front camber. Your caster numbers look good enough. (Camber and toe angles are more critical) |
Lo-Fi Version | Time is now: 26th September 2024 - 09:45 PM |
