Bolt on power enhancements, what would be your first choice? |
jwalters |
Nov 6 2006, 04:53 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
Please, as many people as possible respond to this poll - it WILL affect future availability of bolt-on performance additions!!
Thank you! PS If you are concerned about anonymity, do not be, voting does not identify you, only typed replies do - So please, almost 100 views and only a scant handful of votes?!? Even if you already have your dream equipment do not hold back and vote as if you were once again at the starting grid!! THANKS!! |
jsteele22 |
Nov 6 2006, 05:13 PM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
Subaru EG33 flat six. |
Heeltoe914 |
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
What motor and setup do you have now?
jwalters |
Nov 6 2006, 05:20 PM
Exhaust (headpipes) [ 0 ] [0.00%] You already have the choice of 4 different headers, with the number 1 being the Tangerine Racing headers, the bottom of the list is the Kerry Hunter at about $400 or so...you'd have to have them way cheaper and as good or better than the KH units to sell any Exhaust (muffler) [ 0 ] [0.00%] already a few choices, none have been dyno'd back to back to see who the winner is unless I've never seen it... complete exhaust [ 1 ] [25.00%] see Tangerine for this, costly, yet proven new design cooling fan [ 0 ] [0.00%] the DTM works, and I believe BrianM is working on some design ideas electrical engine cooling in addition to stock [ 0 ] [0.00%] if your cooling system is already taxed to the limit, I wouldn't want to have to rely on something electrical that could fail and take the engine with it.. Tuned intake plenums [ 0 ] [0.00%] so you have thousands of dollars for dyno time?? might need to have a new exhaust to compliment the intake tuned intake assemblies (complete replacement) [ 0 ] [0.00%] see above about the tuned intake... Turbo charger system for fuel injection [ 2 ] [50.00%] I'm building one for myself as we speak..well sorta, I started and just have to finish the intake side of things, exhaust is complete... Turbo charger system for carburetion [ 1 ] while carbs do work with turbos, why stay stuck in the dark ages??? (IMG:style_emoticons/default/huh.gif) UMMM, OK --- May I ask your reason to go through all of the trouble to explain your each and every position for a poll?? |
Mueller |
Nov 6 2006, 05:29 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
(IMG:style_emoticons/default/huh.gif) UMMM, OK --- May I ask your reason to go through all of the trouble to explain your each and every position for a poll?? so much for some freindly advice/feedback......... |
Matt Meyer |
Nov 6 2006, 05:37 PM
Überlurker Group: Members Posts: 216 Joined: 2-December 03 From: Eastern Washington Member No.: 1,411 Region Association: Pacific Northwest |
QUOTE (IMG:style_emoticons/default/huh.gif) UMMM, OK --- May I ask your reason to go through all of the trouble to explain your each and every position for a poll?? Seems like a funny question for someone with over 1000 posts. (IMG:style_emoticons/default/wink.gif) I thought Muller was exceptionally brief. Good thing I'm not done typing my post. (IMG:style_emoticons/default/laugh.gif) And Jake hasn't even voted yet. |
jwalters |
Nov 6 2006, 06:00 PM
(IMG:style_emoticons/default/huh.gif) UMMM, OK --- May I ask your reason to go through all of the trouble to explain your each and every position for a poll?? so much for some freindly advice/feedback......... Easy Mike, I meant no ill will with that question - this is a poll and as such all polls must be unbiased so as to aquire true results. Actually I typed an apology about 15 minutes ago and then was kicked off the board and only just now got back on, just so you know. As you made mention there are a few items being manufactured. However these are not the end all of developement, and as such this question and this poll is of great use to myself and is truly worthwhile of exploring. |
Eric_Shea |
Nov 6 2006, 06:25 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Tires.
jwalters |
Nov 6 2006, 06:29 PM
Tires. (IMG:style_emoticons/default/laugh.gif) Hey Eric, if I sent you 4 rear and 2 front calipers - AND two sets of rear arms (excellent shape) would that get me a set of 5 lug front rotors and a five lug conversion rear with rotors??????? |
nebreitling |
Nov 6 2006, 07:05 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
actually, i think the 914 aftermarket is actually pretty good. for those bolt-on mods that would actually result in reliable performance gains, we already have numerous options.
the only thing i can really think of that is lacking is 15x7 lightweight 4-bolt wheels. |
jwalters |
Nov 6 2006, 07:07 PM
actually, i think the 914 aftermarket is actually pretty good. for those bolt-on mods that would actually result in reliable performance gains, we already have numerous options. the only thing i can really think of that is lacking is 15x7 lightweight 4-bolt wheels. KONIG ----- |
nebreitling |
Nov 6 2006, 07:12 PM
for less than $800/set
Sammy |
Nov 6 2006, 07:17 PM
. Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 |
content removed
grantsfo |
Nov 6 2006, 07:22 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Headers and freeflowing muffler are easiest and best bang for the buck bolt on improvements in my opinion. Then the bolt off options should be considered. (IMG:style_emoticons/default/biggrin.gif)
jwalters |
Nov 6 2006, 07:25 PM
SirAndy |
Nov 6 2006, 07:44 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
If you are concerned about anonymity, do not be, voting does not identify you, only typed replies do - (IMG:style_emoticons/default/av-943.gif) how old are you? 19? (IMG:style_emoticons/default/idea.gif) anyways, i haven't voted because you don't have any "Kompressor" listed. that would be my first choice of forced induction over any turbo system ... (IMG:style_emoticons/default/burnout.gif) Andy |
jwalters |
Nov 6 2006, 07:53 PM
If you are concerned about anonymity, do not be, voting does not identify you, only typed replies do - (IMG:style_emoticons/default/av-943.gif) how old are you? 19? (IMG:style_emoticons/default/idea.gif) "Kompressor" (IMG:style_emoticons/default/burnout.gif) Andy (IMG:style_emoticons/default/WTF.gif) |
Jake Raby |
Nov 6 2006, 07:58 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
QUOTE You already have the choice of 4 different headers, with the number 1 being the Tangerine Racing headers, the bottom of the list is the Kerry Hunter at about $400 or so...you'd have to have them way cheaper and as good or better than the KH units to sell any Several more in development now... Chris from Tangerine and myself are working to bring more options to all the Type 4 applications that are more cost effective, and truly developed- this includes the 914... Chris is taking it seriously and I look forward to the development work- The 914 following has already proven that they are not willing to buy a developed 914 Turbo system. The one I created is in the attic collecting rust because of open ended promises from guys with bigger mouths than wallets... Sorry, but its the truth..The sad part is that mine REALLY worked very, very well and made over 170HP on a 100% bone stock 2.0 with 80K miles on it! |
914forme |
Nov 6 2006, 07:59 PM
SuperCharger = "Kompressor"
But I did not vote because the bolt on for me would be a -6, it is a true built on ahh in. (IMG:style_emoticons/default/confused24.gif) But then about anything will bolt in there, my dad has a bitchin' set of tools we can fix it! |
SirAndy |
Nov 6 2006, 08:30 PM
geee, ever heard of a "Mecedes Benz" ??? (IMG:style_emoticons/default/rolleyes.gif) http://cgi.ebay.com/ebaymotors/Mercedes-Be...050104780QQrdZ1 and yes, you call it a super charger. still missing from your poll-choices ... (IMG:style_emoticons/default/burnout.gif) Andy |
Lo-Fi Version | Time is now: 27th September 2024 - 09:05 AM |
