Noise from the drive line after 10 mph? help |
Willowcreeklane |
Jan 2 2007, 10:46 AM
Newbie Group: Members Posts: 37 Joined: 4-September 06 From: Anaheim Member No.: 6,768 |
Greetings everyone-
I got my 914 up and running, it makes a noise after rolling faster than 10 mph. I was told it was old tires prior to buying it. After putting new tires on yesterday, it still makes the same noise. Coasting w/ trans in neutral, engine near idle, still makes the noise, I'm guessing it rear wheel bearings? or alignmnent? Sounds like (at least I hear it) its coming from the reat of the car. Anybody experience this? let me know. thanks, (IMG:style_emoticons/default/blink.gif) Ed |
Heeltoe914 |
Jan 2 2007, 10:53 AM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Yes it could be Bearing OR????. Maybe alignment but But more likly the bearings Or a dragging caliper. Get it up in the air spin the wheels You mite find it, But be aware the wight of the car on the bearings is more likely to make noise.
Spoke |
Jan 2 2007, 10:55 AM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
My guess is wheel bearings. Lifting a wheel and rotating it may illuminate the bad bearing. Turning a wheel with your hands when lifted should result in smooth rotation without any rolling noise, looseness, or rolling vibration. Any of the above could point to a bad wheel bearing. I have one on my car that sings in left hand turns only.
Spoke |
BMITCHELL |
Jan 2 2007, 10:56 AM
Member Group: Members Posts: 327 Joined: 28-February 05 From: Moorpark, CA Member No.: 3,681 |
Could be rear bearings or possibly the the rear brakes.
The rear brakes are not self adjusting and the PO could have adjusted them to tight. edit:Leamon beat me to it. |
rhodyguy |
Jan 2 2007, 01:23 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
when was the last time you checked the trans gear lube level?
k |
Lo-Fi Version | Time is now: 27th September 2024 - 05:14 AM |
