16" boxter rims, offset |
Griffter |
Jan 23 2007, 11:08 PM
Newbie Group: Members Posts: 5 Joined: 23-January 07 From: Playa del rey, CA Member No.: 7,475 |
(IMG:style_emoticons/default/headbang.gif) anyone runnin 16"x6"50mm offset fronts 16x7"42mm offset rear w/1" spacer 225/50 rear 205/55 fr boxter 5 spoke? And what is the maximum offset you can run w/ 16's without problems?
McMark |
Jan 23 2007, 11:47 PM
I think that for a street car, you can run any size spacer you need to and be fine. Most people say that large spacers will wear your wheel bearings out faster, but I haven't seen anyone back that up in the last 3 years on this site.
jim912928 |
Jan 24 2007, 05:45 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I run the 5 spoke 16X7" rims on all four corners with 205's and no spacers anywhere. Backs fit perfect with no modifications to the rear fenders (pics in my blog). I tried 225's on the rear and they rubbed the inner fender well (only slightly). I didn't want to stretch the fenders.
JoeSharp |
Jan 24 2007, 06:06 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Linda runs the boxter snowflakes on her 72. It has 1" spacers on the front and a 7mm spacer on the passenger rear. The drivers side could not take it and she has 205 50 all around.
nocones |
Jan 24 2007, 09:10 AM
Sportscar lunatic Group: Members Posts: 428 Joined: 17-June 04 From: Santa Rosa, CA Member No.: 2,220 |
Good god man!
Niiice. |
Porsche Rescue |
Jan 24 2007, 11:02 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
6's on all 4 with 205/55's (or maybe 50's, can't remember for sure). Rear is perfect (as Jim says 7's will probably go but it will vary with the car). Fronts are about 10mm farther in than stock but do not rub. I did not see a need for spacers but they could be brought out 10mm for aesthetics. You would not want a spacer on the rear with 7's as you would rub on fender, same with 6's. Outside clearance is the issue in the rear.
Attached image(s) |
JoeSharp |
Jan 24 2007, 05:08 PM
Lo-Fi Version | Time is now: 27th September 2024 - 09:41 AM |
