tranny shifter question |
zen motorcycle |
Feb 22 2007, 05:56 PM
almost not a newbie ( way less than a newbie) Group: Members Posts: 259 Joined: 21-May 06 From: Dallas Member No.: 6,038 Region Association: None |
my shift linkage seems to be eating the nylon bushings for breakfast lunch and dinner. Has anyone run across this before? Also I am leaking gear oil throught the shift linkage attached to the case. How hard is that bushing to change?
thanks |
SLITS |
Feb 22 2007, 06:35 PM
You will find it to be an "O" ring. 40mm X 1.5mm part # 999 701 359 40
or Bushing 914 303 273 00 Seal 900 112 001 50 |
Greenguy |
Feb 22 2007, 10:49 PM
Member Group: Members Posts: 51 Joined: 29-December 06 From: Clovis, CA Member No.: 7,402 |
my shift linkage seems to be eating the nylon bushings for breakfast lunch and dinner. Has anyone run across this before? Also I am leaking gear oil throught the shift linkage attached to the case. How hard is that bushing to change? thanks I just recently removed the cheaper version of a shortshifter from mine (it had gotten into the clutch tube and caused all kinds of problems). Anyway in the process of doing this I disassembled and overhauled the entire shift linkage: replaced all of the bushings, resurfaced both the front and rear shift rods-which I then primed and painted-replaced the spedo angel o ring, shift selector shaft, seal, and o-ring, and replaced all cone screws. The shift selector shaft, shaft seal and o-ring, is the area that you mention is leaking on yours and is a pretty easy fix. In one tech article that I had read it stated that roll pins in the shift selector shaft would have to be pressed out, but I was able to get mine out with a hammer and punch. The hardest part of the whole project was getting the firewall bushing installed. With the overhauled linkage and the original shifter, the car shifts as well as any car that I’ve ever owned, and is a 100% improvement over the short shifter that was in the car when I purchased it. |
Dr Evil |
Feb 22 2007, 11:30 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Bushings for the shifter are available and not expensive or hard to change. If oil is ending up dripping from teh shifter ont he tranny then it is the inner seal which is a PITA to do if you do not have a seal puller. Just collapse it gently and avoid gauling the housing. You will have to remove the whole shift console (2 nuts) so you might as well get the O-ring too. I recommend driving out the roll pin on the inner comb so you can more easily slide the shift shaft back into the housing once the new seal is seated. Doing it the other way involves a little risk of goofing the seal up.
Twystd1 |
Feb 23 2007, 01:04 AM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
Zen Motorcycle,
I have a special Motorcycle pic just for you. If I had a motorcycle with a Blown 914 engine Cheers, Clayton |
zen motorcycle |
Feb 23 2007, 07:49 AM
Zen Motorcycle, I have a special Motorcycle pic just for you. If I had a motorcycle with a Blown 914 engine Cheers, Clayton I guess you rest your feet on the valve covers (IMG:style_emoticons/default/biggrin.gif) so you can supercharge a type 4 just not turbo (IMG:style_emoticons/default/poke.gif) |
Justinp71 |
Feb 23 2007, 02:35 PM
Senior Member Group: Members Posts: 1,595 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Check your transmission mounts. If they are loose or broken it can lead to worn out bushings.
zen motorcycle |
Feb 24 2007, 03:59 PM
Dr Evil |
Feb 24 2007, 04:45 PM
Check your engine mounts as well. You will be supprised how they will look fine, but when you jack your engine up you will see that one may be separated.
Lo-Fi Version | Time is now: 27th September 2024 - 01:53 PM |
