A/C Power, Which pulley runs it? |
greybeard50 |
Apr 19 2007, 12:56 PM
Newbie Group: Members Posts: 46 Joined: 24-September 06 Member No.: 6,909 |
My 912e motor has two pulleys on the outer edge of the fan ~8" and a third (much smaller...3.5") that runs off a Rube Goldberg setup that bolts to the fan hub, brings the power out past the edge of the other two, has a bearing & holder arrangement then the pulley.
Only one is used to run the Alt. Which one runs the A/C? What is the third for? Finally, could the A/C be powered directly from the crank hub in the space behind the air chambers? TIA! |
type47 |
Apr 19 2007, 01:25 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
sounds like you have a pulley for the A/C, a pulley for the alt, and a pulley for the emissions air pump. if i remember correctly, the A/C pulley goes between the fan and the hub that mounts it to the crankshaft, the pulley for the alt is just the big groove that is the same diameter as the fan and the emissions pulley sticks out from the center of the fan.
at least on the 914 type IV motor, the A/C pulley is as described above. i would think that the 912E type IV mounting of the A/C would be the same as the 914. |
Cap'n Krusty |
Apr 19 2007, 01:26 PM
The A/C pulley is behind the fan. You can't see it with the fan installed. Cars w/o A/C have a spacer instead of a pulley. The pulley on the extension bolted to the outside of the fan hub is for the air pump. The Cap'n
904svo |
Apr 19 2007, 01:56 PM
904SVO Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
On a 912E the A/C unit is driven off the outer pulley the larger of the two
the inter pulley drives the smog pump. On a 912E the A/C unit is mounted on top of the engine not on the side like a 914. |
Lo-Fi Version | Time is now: 27th September 2024 - 02:04 PM |
