hmm will this work?, ??????????? |
mrhurtalot |
Apr 19 2007, 03:52 PM
VRRRRRRROOOOOOOOOM! Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 |
kn intake from AA
Attached thumbnail(s) |
SLITS |
Apr 19 2007, 04:01 PM
Just more dirt in the engine. Filter element is less restrictive (read more porous) so particles can get through.
Trekkor could make one with PVC fittings from Home Depot. My opinion - other's opinions may vary. |
Chris Pincetich |
Apr 19 2007, 04:04 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Sure...you might get cooler air over by cyl #2 instead of over the cooling fan intake zone....maybe? Looks nice (IMG:style_emoticons/default/beerchug.gif)
ottox914 |
Apr 19 2007, 04:11 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
I made a similar kit with some plumbing left overs and a K/N filter, mounted directly under the engine lid grill, with no rain tray. I used a GTECH, not the most scientific of testing, and recorded an 8hp increase, and this was after 5 runs, toss the high and low, average the middle 3 runs. I was suprized to say the least. The problem I had was that it was so tall to get right up to the engine grill, that if everything wasn't tightened just right, not to much, not to little, I'd rock it right off the throttle body at an auto cross. Some side to side bracing would have helped.
mrhurtalot |
Apr 19 2007, 06:32 PM
reason its turned that way was because the new vacumme lines i bought, the red one isnt long enough to have the filter turned to the side.
ill be making some bracing soon enought. just not a top priority right now. |
r_towle |
Apr 19 2007, 06:40 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
it will never work.
Take it off, send it to me, I will dispose of it for you. Rich |
mills914/s |
Apr 20 2007, 07:32 AM
Member Group: Members Posts: 253 Joined: 23-December 06 From: Coeur D'Alene... IDAHO Member No.: 7,363 Region Association: Northern California |
I like K&n filters they are less restrictive than normal air filters giving more air flow. Like Slits says (more porous) Thats why you have to oil them the oil catches the stuff that will get through the filter. So actually in my oppinion I think they work as good if not better (if properly used maintained and oiled) than other filters.
Just my 2 cents Seth |
SGB |
Apr 20 2007, 07:42 AM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
I made a similar kit with some plumbing left overs and a K/N filter, mounted directly under the engine lid grill, with no rain tray. I used a GTECH, not the most scientific of testing, and recorded an 8hp increase, and this was after 5 runs, toss the high and low, average the middle 3 runs. I was suprized to say the least. The problem I had was that it was so tall to get right up to the engine grill, that if everything wasn't tightened just right, not to much, not to little, I'd rock it right off the throttle body at an auto cross. Some side to side bracing would have helped. I'm a carb guy, but when I put long manifolds on, it made a colassal difference in torque. That may cost some top end, but high ultimate speed is not what a 914 does best anyway. I think the benifit from this setup may come from the fluid dynamics at work. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:56 PM |
